Results 1 to 18 of 18
Thread: Pool Refillilng
    Mar 2010
    Spring, TX
    1,082
    Pool Refillilng
    In my pool I have a very small opening which is used if the pool needs to be filled. The whole is about 1/4 inches wide or so. There is always a steady stream of water that is flowing from that part of my pool. It does not seem like a lot of flow. Is this something normal or could I have an issue. I did a backwash recently with the full clean about a week ago and the pool water level has seem to have risen after I had it close to the correct water level. Not sure if the flow from the fill up part is the culprit or something else may be. We have not had any rain since then either, so that eliminiates that as a culprit.
    Hopefully all this made sense.
    Thanks.
    13,000 Plaster IG Pool approx
    Hayward C5030 Cart Filter
    Emerson 1081 EB653 1.0 HP 1.40 S.F. 3450 RPM
    Pool Calculator, Pool School, TF Test Kits
    22,550
    Re: Pool Refillilng
    Can you take a picture of what you're talking about and post it?
    Is this an automatic fill?
    Mar 2010
    Spring, TX
    1,082
    Re: Pool Refillilng
    I will take a picture of it. It is not an auto fill I do not think. The is a place to where I have to turn it on like a pool nozzle and then the water comes out. Then I turn it off and the water has the small flow. I put my finger on it for about 10 seconds and it builds up some pressure and then when I take my finger off of it a lot of water comes out.
    22,550
    Re: Pool Refillilng
    Sounds like the valve you turn on is leaking by when closed. Take a picture of that too.
    Mar 2010
    Spring, TX
    1,082
    Re: Pool Refillilng
    Pictures of requested items.
    Re: Pool Refillilng
    Its a fill line and the gate valve needs to be repaired or replaced. It looks like it has been repaired from freeze damage a couple of times. You should make sure there is proper backflow protection to protect your neighbors from potentially contaminated potable water and if not disconnect it and use your hose to fill the pool.
    Mar 2010
    Spring, TX
    1,082
    Re: Pool Refillilng
    Quote Originally Posted by renovxpt
    Where is the gate valve? How can you tell it has been replaced a few times. Can you break it down a little more for me if you would?
    Thanks.
    Mar 2010
    Spring, TX
    1,082
    Re: Pool Refillilng
    Quote Originally Posted by mynewpool
    Thanks.
    Is the gate valve the nozzle used to turn on and off and something inside of that is broken?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Pool Refillilng
    Thanks.
    Yes.
    Mar 2010
    Spring, TX
    1,082
    Re: Pool Refillilng
    What would be the easiest way to do that to replace or disconnect it?
    Thanks.
    Richard320's Avatar
    Jan 2010
    19,009
    Re: Pool Refillilng
    Thanks.
    You replace it.
    I don't see a union anywhere, so the pipes will have to be cut. As long as you're in there, install a check valve. Or just cap the thing and use the garden hose for filling the pool. If the hose is too far away, put a hose bib on the supply line then put a hose on it and fill it that way.
    There's no polite way to say it, but if terms like "union," "gate valve," and "hose bib" are foreign to you, you'd be better off calling a plumber. It's pretty straight forward, so it shouldn't cost a fortune. And bear in mind, if you try it yourself and make a boo-boo, it will be with the water shut off. That means no water to drink, shower, or flush toilets with until it's fixed! And emergency call-outs for a plumber are very expensive. Even some "handyman service" should be able to handle the job.
    22,550
    Re: Pool Refillilng
    Brass gate valves (which is what you have) are notorious for leaking through. There's nothing really broken in it, it's just worn inside. Replacement is the best option. You've gotten good advice above about that.
    Mar 2010
    Spring, TX
    1,082
    Re: Pool Refillilng
    I will have to get someone out to fix it. I turned the handle off more and it seems to have slowed down to a very slow drizzle. Just have to find someone who does good work.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Pool Refillilng
    Before spending any $$ on this, check for another valve in the basement to close off this line. If it has a dedicated valve inside, simply close that one. Sure you'd have to play with 2 valves to top off the pool, when needed, but it costs nothing.
    Luv& Luk
    -Ted
    tsunami's Avatar
    Sep 2008
    Oceanside, CA
    138
    Re: Pool Refillilng
    Do you use this valve often? Some crud may be preventing it from closing all the way. Sometimes massaging the valve, or opening and closing it fully a few times will clean the crud out and enable you to close it all the way. Good luck!
    40 X 26 Free Form Pool with attached 9 X 7 Spa raised 18" with 8 Jets and Spillover, and an Art Rock Waterfall/Grotto with accent rocks, 26,000 gallons
    Intelliflo VF-3050 for Pool, VS-3050 for Spa Jets, VS-3050 for Waterfall/Grotto, Quad DE 80, 400K BTU Mastertemp, Intellitouch i7+3 w/ iS10 10 Function Spa-Side Remote, Intellichlor IC40 Salt Chlorinator, Telephone Remote, 2 Intellibrites for Pool/ 1 for Spa, Solar Panels on 2 story Roof w/ 75% coverage
    Pebble Tec Tropical Breeze Tsunami's Pool Build
    Re: Pool Refillilng
    It looks to me like the valve can be dis-assembled. The valve may be able to be repaired. Some hardware stores carry the seals/washers for valves. May be worth looking into. Then again, that paticular valve may look like it comes apart, but actually does not.
    16K gallon, Pebble tec, beach entry. Two 1 hp Pentair Whisperflos. One for Paramount MDX2 main drain, Paramount debris canister, and Pentair CCP 520 filter. One for skimmer w/sock and Paramount PCC2000 in floor cleaner. 3/4 hp Pentair Pinnacle for waterfall. Fiberstars fiber optic pool lighting. Aqua-Logic AQL-P-4 control panel with wired remote in the house. SWCG system that is not used. Ultra-Pure Ozonator that is not used.
    Mar 2010
    Spring, TX
    1,082
    Re: Pool Refillilng
    Quote Originally Posted by tsunami
    I have never had to fill the pool except once and when I use it, the wate comes out without any issues.
    Mar 2010
    Spring, TX
    1,082
    Re: Pool Refillilng
    Quote Originally Posted by waste
    I tried to takes out some wood boards to where I think the pipes are. I am going to try again another day and see if I can get it fixed.
