Thread: Need help with Aqua Pure chlorinator
    Round Rock, TX
    529
    A friend of mine has the Aqua Pure Chlorinator and it is no longer generating chlorine. To test this I tested the pool water at 2.5ppm FC and then I tested with the Chlorinator set to Boost and got water from the return valve and it also tested 2.5ppm FC. I also looked for bubble coming from a return and found none.
    He replaced the cell at the end of the season last year, so it is brand new. We looked at it as well and it looks brand new.
    I then opened the cabinet, he has a PS4 setup and looked at the control PCB. I can see it go from 90% to boost when I hold the boost button for 10 seconds. The lights say the cell is on and also when it is in the rest period.
    When it is on I checked the voltage at the connectors in the panel and the voltage would change from 12.5V to 3V, toggling between the two voltages. When I set it to boost and measured the voltage it stayed at 12.5V with no toggling at all. I thought that the voltage needed to be between 24V and 30V, at least it is for my AutoPilot chlorinator.
    I disconnected the cable seeing if it would throw a low current error code, ran it for 5-10 minutes and it never through an error code. Not sure if this should have happened.
    I tested the water with salt strips to be 4300ppm Salt, the salinity meter was reading 2800. We hooked up the new salinity tester that came with the new cell and it read 3300.
    Flow reports as fine.
    So what am I missing? Is the secondary card that generates the cell voltage bad? Ideas on what else to check?
    thanks,
    dave
    P.S.-is there a way to calibrate the salinity probe like the AutoPilot?
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Re: Need help with Aqua Pure chlorinator
    That isn't a reliable way to test to see if the cell is working. Try cracking the union on the output side of the cell open just a hair while the cell on light is lit and collecting a water sample from there and test that. Don't loosen it all the way, just enough to get s tiny stream of water coming out.
    The most common cause of low FC levels with a SWG is a low CYA level. Post a full set of water test results, so we can check for problems with any of the other levels. You can also try an overnight FC loss test to make sure you don't have a low level algae problem.
    Round Rock, TX
    529
    Well bummer, I did ever test except CYA I'll try to get that today.
    CC 0
    FC 2.5
    TA 50
    CH 600
    PH 7.5
    Salt 4300 (per my salt strip)
    For the time being they are using bleach to keep the FC up.
    dave
    Round Rock, TX
    529
    Just to close this out, it was low CYA. I had planned on testing that with everything else, but got distracted and forgot.
    dave
