Thread: Fiber Optic Lit Concrete Accents
    We are getting a pretty basic pool package due to our budget but looking at interesting ways of adding some character to our pool deck. We would have loved to do some special deck but money is tight these days.
    I found this on instructables and thought it would be really interesting and something I could easily do during the pool install. Wanted to get some opinions from concrete guys on how this would work when installing and if I would have to worry about cracks later.
    Basically I would pull wire under the concrete (dug in dirt) to several locations around the pool. I would have the wire come up through a 6"-8" piece of pvc that would extend up higher than the concrete creating a hole when the concrete is poured. Then simply wire a white or colored LED light into each hole, cut PVC to height where concrete round sets flush to deck level or slightly below and then clear silicone the discs in to keep water tight. If something happened to the LED you could simply cut out the disc and replace.
    What do you think? I would color the concrete discs to look like accents, during the day they look like solid concrete accents but at night they glow. If you wanted to get fancy you could even buy the little LED control units so they would sparkle like stars or change colors like the intellibrite pool lite.
    Here's how to make them.....
    18' x 36' Vinyl Kidney 24,000 gallons
    Soon to have Salwater system up and running.
    Intelliflo pump, Colorlogic LED Light and a lot less money in the bank
    Re: Fiber Optic Lit Concrete Accents
    Almost everywhere there are severe code restrictions about putting anything electrical within 10 feet of the water. It can be done, but requires special fixtures and wiring procedures (think expensive).
