Thread: algaecide AND bleach?
    Sep 2009
    TN
    49
    Doing startup and going back over pool school info. It seems that bleach is the best algaecide, but some posts have also recommended to use algaecide and bleach together, but only for Spring startup.
    Can I skip the algaecide and just use bleach?
    (We just hit 60 degree water temp and algae started to appear yesterday, will be opening this week.)
    new in 2009 - 18' x 36' IG vinyl liner, 23,300 gallons
    24" sand filter w/ 1.5hp pump
    Polaris 280 cleaner w/ booster pump
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,056
    Re: algaecide AND bleach?
    [center:933wj7qs]
    I'd grab the bleach NOW. Isn't Walmart open 24 hours?
    Algaecide later if you want, but nip it in the bud![/center:933wj7qs]
    I wouldn't bother with algaecide on opening. Algaecide is more useful at closing.
    Sep 2009
    TN
    49
    "Nip It" it is then!
    Thanks
