Results 1 to 12 of 12
Thread: One-speed to two-speed motor swap
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    I have seen a few topics about replacing an old one-speed pump motor with a two-speed motor to improve efficiency (here and here for example).
    I came across this website that said the following:
    One of the main purposes of a volute casing is to help balance the hydraulic pressure on the shaft of the pump. However, this occurs best at the manufacturer's recommended capacity. Running volute-style pumps at a lower capacity than the manufacturer recommends can put lateral stress on the shaft of the pump, increasing wear-and-tear on the seals and bearings, and on the shaft itself.
    I was going to replace the motor on my max-e-glas with a two-speed, and I wonder if this is an issue. I did a quick search, and there are two-speed max-e-glas type pumps out there.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    South Central NJ
    3,192
    Re: One-speed to two-speed motor swap
    Only if you go from a 1.5 HP single to a 2HP Two speed. The 1.5HP two speed is the same,
    Scott
    Owner of - PoolGuyNJ LLC
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    It is actually a 3/4 hp now and going to a 3/4-1/8 hp two-speed.
    You will be fine. All you need is for the high speed HP to match.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Thanks for the help Scott & Jason. A.O. Smith B2980 and Tightwatt2 ordered and on the way.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by svenpup
    ...A.O. Smith B2980 and Tightwatt2 ordered and on the way.
    Me too! Well, different motor for my whisperflow...
    Anyway, is it possible to run a single additional wire in the conduit for the high/low speeds, or does my existing 14/2 copper need to be replaced with 14/3?
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    22,553
    You can run single conductors as long as you're running it in conduit.
    South Central NJ
    3,192
    If it's on a 20 amp breaker, it should be 12 gauge wire. I realize you're not pulling that many amps and 14 gauge will probably be fine, assuming it's under 150' and no other loads are attached. I seem to recall it's near the house and likely to be nearer than that to the breaker or timer.
    Scott
    no-mas's Avatar
    Jun 2008
    FL
    405
    Thanks guys
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    How much pressure should I expect on low speed. Everthing is together, but on low I get no pressure. Is this normal?
    Yes, that is normal. The pressure on low speed will be dramatically lower than on high speed. Often it reads as zero, even though it isn't really zero. The gauges common in the pool industry are not all that good at measuring low pressures.
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    My new energy efficient two-speed pump is in and working. The Tightwatt2 didn't show up yet, so I can't change speeds without rewiring, but now biggie.
    It is amazing how quiet it is on low...basically silent.
    I had a hard time finding a definitive answer, so for anyone looking in the future here it is: replacing a 48y square flange frame with a 56y square flange frame works fine.
