Thread: Anyone use both a hand leaf rake and a robot
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    The house we bought came with a Letro Legend and for the most part I really like it. Several people at work just use a Commercial Grade Leaf Bagger from Leslies. My wife hates when the pressure robot keeps bumping into you so I was thinking about switching. I already have the booster pump to run this instead of using the garden hose.
    Am I crazy for thinking of switching so I ask your advice for those that have used both. One thing I don't like about the Legend is the hose twists itself limiting the range and tilting the unit sideways sometimes. There are two swivels in the hose but the floats seem to catch on the first twist.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Mar 2008
    Central VA
    328
    Re: Anyone use both a hand leaf rake and a robot
    Hmmm...I love my Legend (Platinum), it cuts WAY back on brushing and skimming time with us. It could be that your hose isn't sized right, or doesn't have enough couplers/swivels. You may want to get a local PB to look at it. We had ours professionally done, and they sized it just right so that it hits every corner of the pool, but doesn't tangle up hardly at all, it makes a difference, I think. Also, instead of getting into the pool when it's running, you may want to just run it for an hour or so every morning or evening, then remove it. We run our booster and Legend in the a.m. alot of times, then when the wife & kids are ready to get in the pool, they remove it and set it aside for the next day. An hour or so should be all the time it needs, usually. Happy swimming!
    Todd
    Pool: 16x36, 16,800 gal., vinyl, sand filter, SWG & AquaCal Heat Pump
    Spa: Hot Springs Sovereign, 355 gal., ozone/ion
    The most helpful tool you'll ever have for your pool:
    http://www.poolcalculator.com/
