Thread: Aluminum Fence installed on or in concrete?
    Getting ready to install a 18' X 32' inground vinyl pool here in NC. The final thing holding us up is the fence of all things. For the experienced pool owners out there, how and when do you install the aluminum fencing?
    We plan on putting a large section of the aluminum 54" BOCA fencing on the concrete and trying to decide whether to install when we pour deck, core drill later or used flanged posts to install later. We are a bit worried about installing when pouring concrete and getting the fence "splashed".
    What do you recommend, cost is a consideration....Thanks!
    18' x 36' Vinyl Kidney 24,000 gallons
    Soon to have Salwater system up and running.
    Intelliflo pump, Colorlogic LED Light and a lot less money in the bank
    Dec 2009
    Central Massachusetts
    Re: Aluminum Fence installed on or in concrete?
    Always do the fence last.
    Let the fence builder decide what he wants to do. I've seen them cored out, and i've seen them use the 4 bolt plate with the post over the top hiding the screws. I personally prefer the plate, covered by the post. But you dont want to put it up before you pour the deck.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    I did it last and core drilled. Easy and clean!
    I'm going through this debate myself. It seems to me if I attach with the flanges to the existing concrete deck it would make the install much easier. This is the one thing I will be doing myself to save on the cost. Anybody else have an opinion?
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    Do it after for sure.
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool:
    It will definitely be the last thing I do.
    I'm just considering the install options. I'd rater not dig the post holes if I don't have to and the flange method seems like it would be easy to keep the fence straight and level. I hadn't considered core drilling but I'm starting to think that would okay as well. Has anyone used the oz-post? I'd like to know if they heave in the winter.
