Results 1 to 16 of 16
Thread: Plaster stains (noticed before the fill)
    Feb 2010
    Ponte Vedra Florida
    29
    I noticed some staining in the plaster as the pool was filling, after 5 days the stains have not gotten better, worse I believe. The images below are admittedly bad, I need to take it during the day but I'm rarely at home in time to catch it. That said, I'm sure you can see what I am talking about. The pool is still being maintained by the pool builder.
    My Pool builder has told me that brushing will fix it but that's not the case so far... What do you guys think?
    The below is in another section of the pool, I believe it was cased by some bark that was jammed in the return.
    11,000 IG gunite pool with 8X8 SPA[*]PENTAIR WHISPERFLO 2HP UP-RATE ENERGY EFFICIENT, ]EasyTouch 8SC-IC20 for Pool & Spa with Chlorinator[*]IntelliBrite® Color LED (2),MasterTemp® 400 btu propane Heaters[*]Aqualcal HeatWave SuperQuiet SQ155, Paramount ECOPOOL
    Re: Plaster stains (noticed before the fill)
    Try a vitamin C tablet on one of the stains, hold one tablet against the stain for 30 seconds, and see what happens. If the stain vanishes around where the vitamin C tablet was you have metal stains. I don't think that is the most likely problem, but it is so easy to check for that it seems worth the effort.
    Feb 2010
    Ponte Vedra Florida
    29
    Thanks, I'll give it a shot. Might I ask what you think the most likely problem is?
    If it was bark, then the stain is probably tanic acid which usually goes away with time.
    Feb 2010
    Ponte Vedra Florida
    29
    Only the last stain was bark, that one came after the pool was filled. The others I could see before the water covered it.
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    The first few pics look very similar to what I am facing, too. Do they appear "tannish brown"? Almost looks like dirt but it doesn't move away like dirt when you brush?
    22,000 gal IG Pool & Spa, Fountain and Spa Spillway, Penatair IC-40 SWCG, Pentair Intelliflo Variable Speed Pump, Cartridge, Antigua Blue Wet-Edge
    Feb 2010
    Ponte Vedra Florida
    29
    yes, that does indeed sound similar, have you figured out what yours was?
    Guest
    Let me ask you guys another question: was your plumbing under pressure during the build? I hope this is not the case, but I have seen pools where the plumbing gets hit with a spike during forming for concrete, or a point from a jackhammer goes through a pipe, or a bad/unglued joint, etc. and once the system is fired up it draws dirt in through the break and in to the pool. It doesn't happen often, and most builders know to keep the pool under pressure, but it does happen.
    hawkeyes's Avatar
    Mar 2010
    Dallas, TX
    100
    Quote Originally Posted by reefkeep
    Nope. They think it is calcium scaling. They are doing an acid wash tomorrow. I'm hoping it helps.
    Feb 2010
    Ponte Vedra Florida
    29
    yes it was under pressure, I didn't know why until now, thank you! Can I assume they need to drain the pool to do an acid wash?
    Guest
    They can do an in pool acid wash (make sure they've done it before and know how to do it!). Saves an awful lot of water!
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,074
    reefkeep, I agree that something does not look right . It first appears to me that it looks like a rust stain, but I am not an expert at this . Our pool was very blotchy at first with very few pebbles showing in the beginning. The PB said that the first 30days was very critical in brushing the pool and that the pool will look more uniform the more we brushed it. We also shocked the pool and used chlorine pucks for the first 30days. I had to do daily testing to keep the pH at 7.5 using muriatic acid which he provided.
    The PB put in the plaster, smoothed out the surface, acid washed to get out cream and show some pebbles, started filling the pool immediately after. Stupid me went for a swim when there was about 3 ft of water in the pool. I remember that the plaster was very firm and I stepped very gingerly, however the next day I saw little foot prints in the floor. I was very upset however the PB said not to worry as the more I brush, the more uniform it will look and it will blend in. The point I am trying to make is that it may all blend in eventually.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Feb 2010
    Ponte Vedra Florida
    29
    Well the PB added something, all stains are gone!
    30,431
    Could you find out what he added?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes, please tell us what he did!
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,074
    I am very curious myself
