Results 1 to 19 of 19
Thread: What is your pool temp
    Hello all,
    Just joined this site today, great stuff.
    Just moved from Michigan to North Carolina. Our new home has a in-ground pool. I just opened it and was pleased to discover the water was crystal clear. The water temperature was 54 degrees. It does not have any heated source, was wondering if anyone knew how long it takes down here to heat up. What temps should I expect in April, May, etc. thanks
    My pool is 54 degrees, what is yours?
    David
    Re: What is your pool temp
    Opps, rookie mistake!
    Should have read a little ways down the forum. (already asked)
    Well if there are North Carolina folks around, I would appreciate some pool temps by month.
    thanks
    David
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Welcome! Rookie mistakes are allowed.... but only once.
    Enjoy your new pool!
    I was reading 71 here in Florida yesterday, but no cover and an all day rainstorm probably has forced the temps to drop quite a bit.
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    I live in central NC. You'll have warmer temps closer to the coast and colder temps in the western side.
    Most years we can swim by the end of May at temps around 70-72. (Too cold for me.) By the first of June we see water temps around 80-82. July-Aug I can see temp 88-91. As soon as Sept 1st rolls around my water temperature drops quickly into the mid to low 80's.
    Water temps really vary widely. Year before last, our water temperature was 91 on the last day of school (we had a party). Last year it was only in the mid to low 80's the last day of school.
    My pool is only 10,000 gallons and we use a solar cover at night to keep the temps up. (Not really needed in July-Aug.) We do have one solar panel running and it boosts the temperatures about 2 degrees. We've had our pool running for 6 years and have been using the solar panel for only the last two years.
    Hope you enjoy it down here. I use to live up in Maryland and I much prefer it down here in NC. If you live somewhere in NC from Greensboro north, you'll see some snow every year. It's really funny to see the little trucks they use to clear the roads. It's even funnier when they call off schools for only a skiff of snow. Up north our bus would put on chains and keep on going. Then again, down here they get the ice that we didn't get up in Maryland where I use to live. Either way, the run on milk and bread is still the same when a storm is coming.
    17K Gal. IG Vinyl - 1.5 HP Pentair WhisperFlo Pump - Pentair SMBW 4048 DE Filter - Solar Heating - TF-100 Test Kit
    Pool School - The Pool Calculator - How to Shock Your Pool - Help Support This Great Site!
    Great info, thanks guys.
    Pool is up to 64 degrees. Next 3-4 days outside temp is forecasting 80,s here in NC...cant wait to see what the pool temp will change to. Keep ya posted
    David
    Feb 2010
    Houston, TX
    271
    98. It will be back to 102 by the time we get in tonight.
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Jul 2009
    Charlotte NC
    31
    Speaking of pool temps , I am also in NC and just uncovered my pool for the first time this season. My water temp is also very cold, but now that the
    cover is off and outside air temps to be in the mid 80's is there a temperature my pool water needs to be at in order for any chemicals (shock,etc) to be effective.
    The water is a little cloudy and I vacuumed the debris remnants off the bottom. I have a chlorine generator that wont even operate below a certain water temp.
    Any ideas of what to do in this situation.Can I or should I attempt to shock then adjust Ph/Alkalinity Etc... Thanks
    16x34 kidney shape 19,000 gal vinyl IG
    Pentair IC-20 SWG
    Pentair sand filter
    Pentair 1HP pump
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    64º pool temp here in Fort Worth
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    51 here... MN
    2003 Marquis Euphoria - 400gal
    no-mas's Avatar
    Jun 2008
    FL
    405
    85, but I cheated with the heat pump. 61 when I started heating Wednesday morning. We'll be swimming plenty this weekend!
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Raleigh-Durham here - opened last week. Green, but now a very nice Caribbean green/blue. Another day and it'll be good to go. Water temp is 66 degrees. Once I get the water crystal clear, I throw the solar cover on and the kids will get in when it's anywhere near 75, as long as the sun is HOT.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,068
    85 today but I just had solar installed on Tuesday and it ran from Wednesday till Friday (today.) I started out at 61 degrees....
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    May 2009
    Syracuse, NY
    56
    56 degrees for pool temp this past weekend here in Syracuse, NY. We got to around 85 degrees in outside temp this past Saturday. The morning of the pool started at about 52 degrees. We added some fresh water which was chilly so it might have warmed up some more if we wernt adding water.
    16ft wide x 32 ft long 4.5 deep shallow end with slant straight to deep end of 6.5ft, there is no flat shallow end, Est 20,000 gal. Pump, Hayward Pro Series 300lb Sand Filter, Laars Lite 2 Gas Heater, The BBB Method, TF-100 Test Kit.
    Apr 2010
    Shoreacres, TX
    27
    74* just outside of Houston, TX on upper galveston bay
    16K IG Plaster Pool w/ Hayward 36sq.ft. DE filter I'll have to add the pump info when I can get to it.
    Testing with TF-100!!
    Apr 2009
    Burlington, ON, Canada
    344
    Burlington, ON, Canada. Opened on March 29 to 45f degree water. It was sunny all week and the solar was on. Got up to 71 on the Easter weekend. Rainy and cloudy this week. Water was 62 this morning. Not bad considering I don't have a cover and it's been getting down to 8 celsius overnight.
    16x28 Roman, 55000 litres, salt water, Zodiac Duoclear 130 (mineral cartridge removed!!!), inground, vinyl liner
    Hayward Tri-star VS900 (1.85 HP) pump, Hayward C3030 cartridge filter
    Nine Techno Solis 4x10 solar panels, Jandy LX 250 natural gas heater
    Jandy Aqualink PDA with Sub Panel Power Centre
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,043
    66° F
    It's completely exposed, so that can change fairly rapidly. Hit 71° a few weeks ago during a hot spell, cooled down to 62° after a couple cool, cloudy days.
    Central Jersey location
    Opened last week temp was at 51 deg seemded to go up about 3 degrees a day, but last night the pool temp was 65 and the kids went in at dusk - with wetsuits on
    Still need to take a water sample but I started to add chlorine via the skimmers. My Liquid chlorinator is cloged but I am about to improve it by installing a larger supply line and fittings.
    Kply
    35,000 In-Ground Concrete/Plaster with spillover spa.
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by no-mas
    Me too! I opened at 48 last saturday. Got to 53 with old Sol by tuesday morning. Ran the HP Tuesday and Wednesday and threw the solor cover on. This morning it was 80.4. I'll get the SWG going this weekend and ditch the dichlor.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
