Thread: What causes hardness to increase?
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    Pool started in June 2009 (17.5k gal, SWG). CH was in the 300 - 350 range last year. Tested for CH today (for the first time this year) and have a reading of 400 from the pool store and 450 from the TF kit.
    What causes the hardness to increase? Have only added acid and baking soda on a regular basis.
    We do have naturally hard water, but with our cold winter I can't believe much fresh water went into the pool in the last 3 months (auto fill). Will CH continue to creep up after I drain 20% and refill?
    Thanks
    17,500 Gallon, SWG 33' x 21' freeform w/ Sunstone Cobalt Plaster. Attached 6 X 6 Spa raised 12" w/ 6 Jets with Moss Rock Spillover. 25' Moss Rock Waterfall. Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Max-E-Therm heater, Pentair Intellichor, Pentair EasyTouch 4P, Pentair Legend Platinum Cleaner w/ 3/4 hp pump, autofill system, nat gas fire pit. BBB convert
    http://www.troublefreepool.com/new-tx-pool-t17907.html
    30,421
    Re: What causes hardness to increase?
    What is the CH of your fill water?
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    CH of fill water is 130
    Any time you replace water lost to evaporation, you are adding more CH. Water evaporates, but the CH stays in the pool. Then, when you add more water, you are adding more CH, so the level will constantly go up. There are two ways to reduce the CH level, remove water from the pool (splashout, backwashing, or pumping water out) which removes CH along with the water, or get a service company to do a RO treatment.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    You're not using Calcium Hypochlorite for Chlorine are you?
    coog61's Avatar
    Nov 2009
    Richmond, TX
    84
    have not used Calcium Hypochlorite
