Thread: Just starting with salt.
    Mar 2010
    Goldsboro, N.C.
    41
    I am changing over from chlorine to salt when i take the cover off in a few weeks. Do i go ahead and start putting salt in the pool when i turn the pump on, or do i need to shock and add all the other chemicals first to get everything stabilized before switching completely over to salt?
    Thanks
    25,000 gal. I/G Vinyl Liner Pool; Pentair IC40 SWCG; 3/4 hp Hayward Pump with 244t Hayward Sand Filter
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Just starting with salt.
    I would clean, shock if necessary and balance everything out first.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    30,432
    So any newbies don't misread your post......
    A salt pool is a chlorinated pool. The SWG is simply a different way of getting chlorine into your pool than you have been doing
    It doesn't really matter when you add the salt. Salt won't really affect anything else. On the other hand, it is a good idea to get everything clean and balanced before you turn on the SWG.
