Thread: Difference Taylor PH R-0004 & R-0014
    Got my test kit a few years back from TFTestkits. Ordered some refills this year, but forgot the PH solution. Stopped at Leslie's today to get a refill bottle. Went to test tonight and 5 drops set it to a deep red. Then re-read the directions to make sure it was 5 drops and noticed my kit calls for R-0014 not R-0004 like I got. Trial and error seems to be 2 drops. Anyone have any input if this method will work with the Taylor K-1000 PH/chlorine kit?
    12,200 gal.
    grey plaster
    IntelliChlor SWCG
    Starite System 3 DE filter
    Re: Difference Taylor PH R-0004 & R-0014
    R-0004 and R-0014 are the same except for the concentration. R-0004 is designed for a larger water sample. Instead of requiring more drops, they made it more concentrated. If you are using a view tube designed for R-0014, then you won't need as many drops, which is exactly what you discovered on your own. The test results are still valid.
    Thanks. The 2 drops was the only combo that gave me a similar color to the vial, so I assume that is the magic number.
    12,200 gal.
    grey plaster
    IntelliChlor SWCG
