Results 1 to 10 of 10
Thread: ANOTHER newbie question
    New pool and having trouble keeping PH up. I was anticipating having issues keeping PH down. IS that usual for a new build? I have a feeling that when we get the SWG going it could balance itself pretty good. PH at a 7.0. Water in the pool for about 20 days is it safe to add borates?
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: ANOTHER newbie question
    What is your TA? I would wait on the borates. Yes it's unusual.
    TA=160
    Mar 2007
    San Rafael, CA USA
    12,082
    If you are still using Trichlor pucks, then these are very acidic so would tend to have the pH drop, even with elevated TA (though that helps a bit).
    just chlorine
    should i attempt to raise?
    Mar 2007
    San Rafael, CA USA
    12,082
    You could try aerating the water more by pointing the returns up -- that might help. Or you could explicitly add a base to raise the pH, such as adding 20 Mule Team Borax. It's really strange to have the pH be dropping when you're using chlorinating liquid or bleach (or Cal-Hypo or lithium hypochlorite). Very strange, indeed.
    22,548
    Where are you located?
    Have you gotten a lot of rain lately?
    The reason I ask is that the rain here is low pH and we've gotten a bunch of it. I've had to pump a lot of water of and have subsequently been fighting low pH more than normal because of it lately.
    Butterfly's Avatar
    South Carolina
    10,045
    Is it possible that your test reagents are expired?
    Not saying that you do , but many of us have a slight color blindness and find the test a little difficult to read.
    Is more than one person seeing the test color and agreeing on the pH?
    Just throwing out some ideas, since your pH seems to be an enigma.
    You're done SLAMing when:
    11,969
    Is the pool covered?
    Asked my wife to tell the PBer a week ago that the PH was low. She did and his response was "Id call your pool guy to fix it- OH- your pool guy is your husband (me)." Sounds like the pool is now under our care right?. Well what I just figured out was that the pool is under our care BUT he put a gallon of acid in the pool the day before. Dropped the PH to 7.0. It is now back up to 7.5 as of this morning. Situation normal- minus the communication on that one.
