Results 1 to 18 of 18
Thread: Sweet!
    Sweet!
    Today is the day.
    Re: Sweet! Update?
    Ok, I just got a call saying they have hit some ground water. He said in about 3 hours we have about 4 inches of water in the deep end.
    He said to fix the problem they spread rocks/gravel and attach a PVC line under the pool to pump out the water from under the liner.
    How big of a problem is this and should I be worried?
    He said that it shouldn't be a problem and as long as we have good drainage for the surface water we should be ok?
    Vero Beach, FL
    462
    Re: Sweet!
    That's what they did for us with no problems. Our deep end is 6 foot and at that point we had over a foot of water. They had to dig down an extra couple of feet, put in a pvc pipe, and dump rock in. The pump ran 24/7 all during contruction and pumped into a swail until the pool was full. At the end, they capped it off and I suppose it would be used again if I ever needed to drain the pool.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Re: Sweet!
    Quote Originally Posted by lborne
    I think that is kind of what he is saying. He made it sound like it wasn't a big deal and they run into a lot. Just makes me nervous.
    Nov 2009
    Indialantic, FL
    323
    Re: Sweet!
    I'd guess I'm about a 90 minute drive north of lborne.
    In my area they are surprised when they don't hit water.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
    Re: Sweet!
    Updated pics.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Sweet!
    With the ground water - just remember that in the future, should you need to drain, try never to drain too much out of the pool at once as it could cause the liner to float and/or wrinkle.
    How exciting!
    South Central NJ
    3,192
    Re: Sweet!
    Connecting the dry well line to the pool suction and valving it off when not needed is very handy. In ten years, when you change the liner, you will, or the tech will see it and say YES! Thank You!
    Scott
    Owner of - PoolGuyNJ LLC
    Re: Sweet!
    Hard to belive they can do all that in 2 days.
    Pool-creetin's Avatar
    Mar 2010
    Michigan
    181
    Re: Sweet!
    Very nice pool!! Maybe one day I can do that.
    26x16 rockwood keyhole vynil inground, waterway cartridge filter and swg, variable speed pentair pump, extra large skimmer with 2 main drains in deep end and 2 returns,Rheem raypack 206 natural gas heater, hayward tigershark qc robot. Being installed in late may early june. Woot!
    Henry Porter's Avatar
    Nov 2008
    Sweden
    604
    Re: Sweet!
    Hi dankfoot!
    It looks like a very nice and tidy work. Just out of curiosity though! I expect they coulden't have compacted the soĆ*l around the pool beacuse it's not filled yet. Do you know how they going to get the soil compacted all way down once you start filling?
    There are probably a very good way of doing so, I just coulden't figuring it out!
    looking forward to more pictures
    Inground concrete pool 14600 gallons,Pentair Whisperflo 3/4HP WFE-3, Hayward swimclear 420sq ft
    Zodiac LM3-24 SWG, Dolphin Diagnostic poolrobot, Heatpump Gullberg&Jansson 13,8KW, TF testkit.
    Seen a shooting star tonight And I thought of you You were trying to break into another world A world I never knew
    I always kind of wondered If you ever made it through Seen a shooting star tonight And I thought of you
    Re: Sweet!
    Henry,
    I asked if they compact the soil and they said no. This company does not pour the concrete until 3 or 4 weeks later. So with the rain and time the soil will compact on its own. I also asked about the dirt right around the top of the pool and they said they just fill that in with concrete.
    I hope that helps.
    Dank
    Re: Sweet!
    be careful of the uncompacted dirt... I'm 6 months post construction and already have cracks in the concrete b/c the concrete guy said the dirt and fill had settled enough.. plate compactors are about $60.00 a day to rent... replacing concrete...well ...not so cheap
    Grant and Jerri
    Liberty, NC
    New 18x36 vinyl liner pool with lighting and fountain
    Re: Sweet!
    Grant, How long did they wait to pour the concrete?
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Re: Sweet!
    The dirt will not settle very much in a month... I would compact. A day spent out there with a compactor would be a very wise investment.
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Jul 2009
    Shawnee, Kansas
    92
    Re: Sweet!
    Are there any final pics?
    Matt
    20,000 gallon, sand filter, IG vinyl
    Sep 2009
    Greentown, IN
    914
    Re: Sweet!
    So wish we could've done and inground... & we haven't even had the chance to swim in it yet (installed late last fall) We didn't have the budget for inground, and where we wanted to place ours we would have had to move some of our septic system and potentially a phone line.... even more costly. Plus... the cost for a fence to meet codes!!
    I admire your new build and look forward to more pics!
    Indiana, ABG 24'x52" Galveston by Blue Cascade (Craigslist buy w/part of deck included), 13,500 gallons, Intex SWG, solar panels mix 2, TF-100 test kit.
    Test kits compared
    Purchase test kits
    Jul 2009
    Shawnee, Kansas
    92
    Re: Sweet!
    Matt
