Thread: Hello from Clearwater, Florida!
    Hello from sunny Clearwater. I've been a long time pool user, and a 10+ year pool owner over the last 3 houses I've lived in. I hadn't had a pro pool company in over 6 years and hoping to keep it that way!
    That said, I definitely need help. The pool I'm caring for now came with the foreclosure I bought back in the fall. When I purchased it, the pump was dead (an old AOSmith/Hayward 3/4 horse), the cartridge filter was run to black and full of rocks and debris and the pool water was pea-soup thick and black. Me and my buddies, while the pool was 2/3 full, removed two full pickup loads of garbage from the pool. Plastics, wood, bricks, stone block, rubble, grass and leaves, you name it. It was quite literally the most disgusting cesspool I've ever seen. It's quite obvious it hadn't had any care in the 3+ years the house was empty.
    Since then, things have gotten a lot better. I've replaced the filter and pump with that in my signature and re-piped most of the system. It runs! it pumps! it fills the new cartridge within an hour or so with spongy green/yellow filth.
    At the advisement of several pool owner friends of mine, I've done the following to attempt to clean up the water:
    - Gotten the pool chemicals from Pinch A Penny and worked to balance the Ph and other factors of the water. At this point, I've got water that floats in and out of the "good" range and won't hold chlorine.
    - Poured chlorine in as a super shock as requested. This really seems to be doing the most good, but I've still got some milky green to the pool.
    - Ran the pump 24 hours/day, every day, for the last 3 weeks.
    - Taken the cartridge out several times/day, hosed it down with a water hose, cleaned the crevaces and reinstalled. Cleaned both the skimmer basket and the basket in the pump while I was in there.
    - Ran the skimmer-powered pool vacuum over the bottom and walls of the pool dozens of times, giving it the opportunity to soak up any remaining sludge or leaves. As of the last cleanings with this method, I've gotten very little from the bottom.
    - Scrubbed the sides with a hard bristle brush and then a nylon brush. The sides are now in pretty good shape, considering their still touching the green water.
    - Did a "Water change" similar to a fish tank, draining the pool half way and refilling with fresh water twice down, allowing 5-6 days between each cycle to thin out anything in the water. This hasn't helped as much as I'd have liked.
    So, all of this done and I have a few issues:
    1. Water still green and milky.
    2. Pump seems very labored and has shut itself off two times within a few minutes of turning the main drain on full and the skimmer off. Could I still have stuff stuck in the main drain pipe? Is there an easy way to snake this out with water in the pool? Alternatively, if I turn on only the skimmer, it works great!
    3. Several people, including two pool companies I called, suggested I drain the pool and start over. I'd really hate to do that. Am I completely unreasonable or is that the course of action I should take?
    I'm at a loss as to what to do next. I appreciate any help anyone can be
    Denis
    Clearwater, Florida
    12,000 gallon kidney shaped gunite pool
    Pentair Whisperflo 3/4HP Pump
    Pentair CCP420 420sq/ft Cartridge Filter
    Pentair Intellibrite 5G 120V Pool Light
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Hello from Clearwater, Florida!
    Hi Denis (moved your post to "just getting started", then thought about it, and your not a noob, exactly, so I'm sending it to Algae-Prevention and Treatment ).
    A few questions for you. WE CAN HELP! It sounds like you doing most of it correctly, prob just not enough bleach....
    Do you have a test kit? If so what is your CYA level, if any? Can you post a full set of results...
    Start in Pool School - read "How to Shock your Pool". Also read "Defeating Algae" and the sister-article "Turning your Green Swamp into a Sparkling Oasis".
    The chlorine is being consumed as you add it. You have to keep adding it, until it holds. It's going to take GALLONS. Considering the description you gave, it's going to take some POP (pool owner patience) to clear it. Hang in there!
    (I can't advise about the main drain, so I'll leave it alone. except to say since the pool was closed it's always possible the md was sealed cuz of an old leak?)
    Hope this helps...
    You can try to flush the main drain pipe back into the pool using an attachment for your garden hose called a drain king. You need to turn off the pump, open up the pump strainer basket, remove the basket, set the valves for drain only, put the drain kind into the inlet pipe and push water backwards through the pipe. Often that will flush any debris back into the pool. While debris in the pool isn't ideal, it is better than the alternative.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Denis and welcome
    You have had a huge project on your hands. Sure wish we could see some pics!
    If you do not have one of the recommended test kits (see Test Kits Compared here ) for now just take a water sample to your pool store and have it tested.
    Post back all test results.
    Folks will be around to help you clear your pool and create a sparkling oasis.
    You're done SLAMing when:
    Thanks for all of the help, guys and gals! I finally have my water levels at what the Pinch a Penny guy says is adequate.
    Chrlorine is 3ppm and holding.
    Ph is about 7.2-7.3
    He said Calcium levels were good and I have no phosphates detected
    Pool is clearing up!
    I ended up floccing it and vacuuming the waste yesterday and it's been running against the filter ever since. I can finally almost see bottom!
    Clearwater, Florida
    Congratulations, that is great progress!
    If they gave you specific test results, you should post all of them What a pool store thinks is a "good" level and what people around here think is a good level often have very little to do with each other.
