Results 1 to 7 of 7
Thread: Salt content discrepency
    I have had my salt tested at 2 differnet pool stores, and with my strips and they all came back at 2500 ppm. My aqua rite Goldline reads 3200 ppm. The water temp is around 60 and all other chemicals are within range. What would be the reason that the readings are different. Thsi is the second season with the cell, and I just cleaned it.
    Thx
    17,200 in ground Vinyl pool......
    Salt Water
    Sand Filter
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Salt content discrepency
    I do not know the answer, but I do have a question. What is your water temperature?
    You're done SLAMing when:
    About 60 degrees.
    Salt Water
    Sand Filter
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Wild Duk
    About 60 degrees.
    just realized that I missed that in your original post.
    Salt tests are never all that precise. The better tests are +-400, and the rest are worse than that.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Push the diag. button 5 times. What is that reading?
    Factory Warranty Station for:
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    Because they different tests. Some test strips are a sodium only chemical test, your unit uses electricity to measure resistance/conductance and then "guesstimates" salinity from that, with sodium being only a part of the Total Dissolved Solids (TDS.) Titration can be regarded as more accurate, but I doubt that you are getting that test from a store for free. If a store is using a hand held meter to test, ask them "When was the last time it was standardized/calibrated?"
    In the end, it really doesn't matter though. What matters is "Will my unit operate at the level it senses?" It is probably capable of operating on a much wider range, but limits need to be set, don't they? Do you know what the limits are? Probably can't adjust them, so it doesn't really matter either.
    Say the pool stores are right , and you are at 2500. If it senses 3200, and works, you are good to go!(with 28% error.) If it reads 2500 and stops working due to "Low Salt" then you need to add salt for it to work (but you have 0% error! ) Would you rather have a working unit, or an accurate one?
    When DH says that she is cold, the furnace comes on no matter what temperature the thermostat says the house is! Why disagree with her, or your unit, just keep them happy and life is easier!
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
