Results 1 to 8 of 8
Thread: STAINS and CHEMISTRY
    I need some advice. I have some streaks and stains in the plaster. The pool is about 18 years old. My water has been very stable with rock solid readings. I use Autopilot Total Control SWG. My latest readings are:
    FCL 1.68
    TCL 1.72
    PH 7.4
    ALK 50
    CH 340
    CYA 60
    Phosph 250
    Salt 2890
    Temp 74
    The PB says that the reason for the staining is low ALK and recommends that I increase it. I am worried about increasing ALK without knowing how that will affect everything else. I have used United Chemicals Red but did not remove the stains. Help please. Thanks.
    Richard, Temecula, CA
    28,000 Gal. In-Ground Black Marble Pebble Tec and tile, Intellichem with Chlorine and PH control, Pentair EasyTouch 8, ScreenLogic Wireless, Intelliflo VS+SVRS pump, Intellibrite lighting, Pentair Quad 100, Solar heating, Pentair Mastertemp 400 Gas Heater, Water feature spillover from SPA.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: STAINS and CHEMISTRY
    That's nonsense. The TA is a little low but that would not affect the stains. You can add a little baking soda to raise the TA up to about 70. Learn to use the Pool Calculator to figure out how much Baking Soda to add.
    I can tell you your FC is too low. Do you have your own test kit?
    You can test stains a few ways, you can put a vitamin C tablet on the stain, if it's iron it will fade.
    You can place a chlorine tablet on the stain, and if it fades, the stain is organic. Try both and post back with the results.
    Also, if you could post some pics of the stains that would help too. Use a photobucket.com or similar host site to upload your photos. Holler if you need tips on getting the photos to show up.
    How long have you had the stains, and do they seem to be spreading?
    Streaks and stains are not going to magically disappear with just a slight adjustment in water chemistry unless they just suddenly appeared. If this condition happened over a period of time you will most likely need to take some more drastic measures. You may consider a standing acid wash or a drain and clean procedure. The person you need to contact is Randy Dukes at PoolFinishes.net. I have nothing to do with his company nor do I receive anything for this recommendation. He is one of if not the foremost authorities on swimming pool plaster. It is who we call when we have any kind of staining, streaking or plaster issue.
    Frank Bowman
    http://www.SplashPoolsMD.com
    http://www.FrankBowman.com
    Authorized Dealer: Pebble Tec, Paramount, Aquamatic Covers, Pentair, Crystal Fountains, Jandy, Hayward
    Dec 2009
    Central Massachusetts
    2,690
    Ok now lets dont get too drastic here until we know whats going on. FPM has good advice. The vitamin C tablet held on the stain will tell us if its iron or not. If it's iron, it will disappear pretty fast. That would mean you have iron in the water at some point and it deposited on the pool surface. If thats the case, there is a pretty basic procedure one can use to manage that w/o a drain and wash, probably. An ascobic acid treatment can be done thats detailed really well in Pool School. If that doesnt work, it could be organic. As FPM said, holding a trichlor puck on it for a bit will lighten it up if its organic. Pictures will help a lot for folks on here to see the stain. If you will listen to advice here and follow step by step, a drain wash and refill most likely is not needed. Of course, in some cases, that could be the case, but thats down the road. It could be as simple as ascorbic acid treatment and adding a sequesterant.
    And yes, out of whack chemistry can make a managable metal problem worse.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by SplashPoolsMD
    Frank, we don't generally get that excited about some stains
    They're pretty common and usually easily handled by the forum member, based on recommendations of other members here on TFP.
    You might want to spend a little more time in our Pool School, to include further reading, to really understand what TFP is all about.
    You're done SLAMing when:
    Thank you so much. I will follow FPM's advice and test with both, vitamin C and the Chlorine puck. I will also take pictures and post them. I use two different test kits. The Taylor and also a LaMotte with electronic colorimeter. Readings are very consistent. As far as low FC, I have been running the SWG at less than 20% power. I will increase a little. Will report back.
    Aug 2009
    North Central Texas
    1,358
    What is the difference between a "standing acid wash" and the Ascorbic Acid Treatment?
    Thanks, gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    An acid wash is generally done with muriatic acid, which lowers the PH a great deal. Ascorbic acid does happen to lower the PH a little bit, but is used because it is a reducing agent, which reduces the oxidations state of the metals, allowing them to come off the surface.
