Results 1 to 9 of 9
Thread: Do you know this type of stain?
    HardTrance9's Avatar
    Oct 2009
    Los Cabos
    184
    Hi there,
    There is a new pool (not added to the signature yet) which has a couple of stains (pictures attached). Small pool.
    Please let me know if you need any extra info.
    pH: 7.8
    FC: 2
    CH: 1,000
    TA: 60
    CYA: 0
    Salt: 4,100 (strip)
    Salt: 3,000 (Aqua Rite computer)
    The stains look like cigarrette burns on the hot tub.
    Any ideas if they can be removed or why do these come out?
    Just to pictures of the biggest one. There are like other 2-3 very small at the hot tub and pool and no more.
    In charge of some SWG and Bleach pools... still a newbie..
    Nov 2009
    Katy, TX
    94
    Re: Do you know this type of stain?
    I had something similar in my pool wall....after much exploring, it turned out to be a piece of wire (had to dig it out and fill hole with composite)...Good luck
    Inground with 7x7 spa (spillover)
    20k gal plaster (sunstone)
    pentair 3/4 hp (filter), 1 hp (spa), 1/2 hp (features)
    cartridge filter
    SWCG IC-40
    Polaris Platinum (with booster)
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by serge
    I had something similar in my pool wall....after much exploring, it turned out to be a piece of wire (had to dug it out and fill hole with composite)...Good luck
    That's what it looks like to me too.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    the CH is 1,000?
    Oct 2009
    Los Cabos
    184
    Hi all.
    Yep, the CH is 1,000 (tested twice).
    Wire...mmm I think you are correct! Actually I think it could be some sort of rebar... they build pools like that here and someone mentioned something about the wires or rebar causing those stains..
    Knowing this, I think the pool owner won't remove these stains.. maybe it is expensive...
    Thanks!!
    Jul 2007
    Rockville, CA
    99
    I am willing to bet you could remove that stain with a vitamin C tablet. Just hold the tablet with a finger and rub with moderate pressure. It may come back sometime later, but treat as above whenever it shows, and it will disappear.
    20K inground gunite w/ Aqua Logic automation and chlorination Sta-Rite 400 K natural gas heater and cartridge filter 2 HP pump 1.5 HP spa bubbler for spillover spa 1 HP dedicated Letro Legend cleaner
    H2O: two parts Heart and one part Obsession. ~Author Unknown
    11,969
    Good idea flintstone, can't hurt to try and an easy fix if it comes back.
    Heckpools's Avatar
    Feb 2009
    New Jersey shore
    318
    i was also thinking rebar.. CH of 1000 is a weee bit high also
    [center:3gj9kdnn]Matt Heck
    "HECK OF A POOL SERVICE LLC"
    Serving Ocean co. NJ
    COMPANY INFO BELOW
    http://maps.google.com/maps/place?hl=en ... 2995187987[/center:3gj9kdnn]
    Oct 2009
    Los Cabos
    184
    Quote Originally Posted by flintstone
    Ok, great! I was wondering what could work to remove the stains... Will get some Vitamin C and test...
    Will let you know!
