Results 1 to 19 of 19
Thread: CYA mystification...
    Aug 2009
    Central PA
    64
    Happy Spring everyone!
    So this is the beginning of Year Two with our vinyl in-ground. Last year we used the Nature 2 system that was included in our installation. This year I thought I would try BBB, so I'm sure I'll be on here a lot.
    Did my first water test with our new Taylor K-2006 and am confused by the CYA result... I believe I followed the directions correctly, but I could easily see the dot even with the vial full (meaning a CYA of less than 30). Now here's the bizarre thing: as of 10-9-09, our pool store's test showed our CYA at 90. Other info - pool's still closed with winter cover on and no filtration.
    From my understanding, CYA doesn't go away unless you change water, so what am I missing here?
    Steve
    29,000 gal. vinyl in-ground mountain lake (freeform); Hayward DE filter, 2 skimmers, AutoPilot SWG, 2 - 4 X 20 Fafco Solar Bears with Goldline control, Aquabot, LoopLoc winter cover, Pool installed March 2009...
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: CYA mystification...
    You could easily lose that much over the winter. Rainwater is the primary culprit. Add to that the fact that pool stores are often inaccurate in their testing.
    South Central NJ
    3,192
    It probably settled lower in the water. Testing water that has been relatively still for months will never yield good results.
    Scott
    Owner of - PoolGuyNJ LLC
    Aug 2009
    Central PA
    64
    Thanks for the ideas, John & Scott... I wondered if my results could be some combination of what you each posted. Guess I won't worry too much about it until I get the filter started up (but that won't be for a while yet). Right now just trying to get my arms (& head) around BBB & what I need to do.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    The disappearance of CYA over winter has been a mystery for some time. I'm in eastern PA and mine goes to below measurable amounts from 60 at closing in October. In my case it can't be that it sinks to the bottom because I agitate the pool water before I run tests; even so, CYA will be way below 30 when I open.
    In some pools, perhaps in some areas of the country, CYA does seem to go way over winter.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Mar 2007
    San Rafael, CA USA
    12,082
    If a pool is "let go" over the winter with the chlorine level getting to zero, then bacteria can convert the CYA into ammonia thereby lowering the CYA level and creating a seemingly insatiable chlorine demand upon spring opening. This is described technically in this post and my personal experience with this phenomenon (by accident) is described in this post.
    As was noted, winter rain dilution is another way for CYA to get lowered. Other causes for a drop are still a mystery, but we may figure it all out at some point.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Was the water circulating before the lower test result was done? Was the sample done on cold water?
    Dec 2009
    Central Massachusetts
    2,690
    Quote Originally Posted by chem geek
    If a pool is "let go" over the winter with the chlorine level getting to zero, then bacteria can convert the CYA into ammonia thereby lowering the CYA level and creating a seemingly insatiable chlorine demand upon spring opening. .
    My CYA is usually almost 0 when I open as well. Down from ~60 ppm on close. However, i've never noticed a large increase in chlorine demand on opening nor a particularly large CC level either, as you might expect with a high level of ammonia (I've never tested for ammonia on opening the pool, but I plan to this year just to see what it might be).
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    22,549
    My CYA went from 50 to 25 over the winter but I know without a doubt what caused mine to drop. It was rain. We've had a terribly lot if rain this year and I know I've drained an amount that would equal 3/4ths the pool volume over the course of the winter.
    Aug 2009
    Central PA
    64
    FPM: my test was done on non-circulating water (my pool is still "closed" for winter - i.e. winter cover is on, and pump & filter are drained). While my thermometer is not in the pool, the water is certainly cold , however the sample was room temp when tested.
    I would not doubt some dilution due to rain and snow. Because the pool water was frozen for at least a couple of months, I don't know how much snow translated to actual water gain / exchange. That's one disadvantage to the winter cover - you can't see what's goin' on. I assume at least some snowmelt would have seeped through.
    This discussion and related links that have been posted have made me think that maybe CYA buildup isn't as big a deal for folks in cold climates who close their pools for five or six months out of the year. Perhaps this is heresy - but I'm a pool newbie so I'll take cover behind that status
    11,969
    risking heresy already!
    Just kidding... I think there are many factors at play - CYA buildup was a problem for me and my pool freezes in the winter. Every pool has it's own circumstances...
    Say your pool is open for 6 months of the year and you add 2ppm of chlorine each day using trichlor. For each ppm of chlorine, trichlor also adds 0.6 ppm of CYA, over six months (182 days) that would be about 218 ppm of CYA. Even in just one season, starting at zero, you will start to have serious problems.
    Aug 2009
    Central PA
    64
    Hey, it was only an (perhaps a dim bulb) based on what I've begun to read and my meager one season. I started at zero and ended up at 90 (which I understand is higher than one would like). Probably would have been even higher as you suggest, Jason, were it not for our decent rainfall here in PA to dilute things.
    I will be very interested to see if the readings change at all once I get the pump and filter running again.
    Will also test for ammonia (I have an aquarium anyway) just to see if that's a factor.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by Steverino
    Just FYI -- if you add chlorine to the pool and shortly afterwards you measure Free Chlorine (FC), then you don't have ammonia. Chlorine and ammonia combine very quickly (in seconds) to form monochloramine that measures as Combined Chlorine (CC) and not FC. Yes, you could use your ammonia test kit to test for ammonia if you want -- just note that it technically measures the sum of ammonia and monochloramine (if you haven't added chlorine to the pool yet, then if the test is showing ammonia then it's really ammonia). The ammonia test kit actually adds some Dichlor to the water sample to convert any ammonia to monochloramine and then a dye is used that measures monochloramine directly. So to recap,
    FC = free chlorine only (hypochlorous acid, hypochlorite ion, chlorine bound to CYA)
    CC = monochloramine plus other combined chlorine (e.g. chlorourea)
    Ammonia test = ammonia + monochloramine
    Richard
    Aug 2009
    Central PA
    64
    Thanks for the advice, Richard (and everyone!).
    I do have one additional question that's related to the low CYA... As I look to start up the pool, I have lots of pucks left over, as the Nature 2 has a compartment to dissolve them over time. To reintroduce CYA, I assume I can run some pucks in the Nature 2 (sans cartridge of course), but I'm afraid the rate of CYA gain will be too slow (the pool is 28,000 gal, and they dissolve very slowly in the Nature 2).
    The winterization kit I used has a floaty - I guess I could also throw some pucks in it for now.
    Would I be better off just buying stabilizer instead?
    Dec 2009
    2,690
    Thats what I would do in your situation.
    22,549
    I'm of a different opinion. Since you already have the pucks and you need CYA. I'd go ahead and drop them in the floater and use some if them up. It's not like you have to be in a big rush to get the CYA up. Just keep a check on your FC level while you do it. OF course that's just my opinion.
    There are many ways to do it, and they all work. Personally, I would save the trichlor for use sometime when I was on vacation.
    Jan 2009
    Cupertino, CA
    1,966
    Well, my 35-lb tub of 8-oz tabs would have started with 70 tabs, figure I need 3-4 (avg 3.5) for a week away, in practice not needed in the winter so figure two times a year, makes 7 tabs per year.... that is, one tub is worth about 10 years of vacations.
    I make it that the 35 lb of trichlor is cheaper than the equivalent 20 lb CYA + 30 gal 12.5% bleach, at least per Leslie's trichlor and CYA prices. I'll stick with trichlor for boosting my CYA each spring. While the water is still cold, low CYA is not an emergency, so I'm okay with it taking a few weeks.
    --paulr
    BBB "Intermediate Swimmer"
