Thread: What happens if you are in the middle of shocking...
    skydiva44's Avatar
    Houston, Texas
    200
    the pool and the water temp drops to 55. Should I continue or will it do any good with the temps going down into the 30's tonight? Yes it was in the high 70's when I started the process....
    ABG Easy Set 18 x 48
    5455 gallons
    SWG
    Intex Pump 4000 GPM - Size B cartridge
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: What happens if you are in the middle of shocking...
    Keep at it. The algae will slow down due to the cooler water, but it doesn't go away until you kill it.
    22,543
    I would continue on with it. The reactions will slow down but it'll still happen. You don't want to lose ground by stopping because it'll be getting warm again soon and if you allow the algea to gain ground you'll have to use even more chlorine to kill it back to where you were.
    skydiva44's Avatar
    Houston, Texas
    200
    Thanks guys!
    5455 gallons
    SWG
