Results 1 to 20 of 20
Thread: Pool repair
    Sep 2009
    Bellmawr, NJ
    31
    Pool repair
    I purchased a home with a pool back in November.
    First home, first pool.
    The pool was in complete disrepair.
    Vinyl liner brittle, cracked, and torn.
    Pump and filter assembly never drained prior to either of the two winters the house was vacant.
    The concrete pad around the pool is cracked and settling/sinking near the stair end of the pool.
    I have no idea the condition of the majority of the pieces of the pool...I see the steel walls...and fiberglass steps...and rusty-looking filter/pump.
    I was planning on breaking up the already broken concrete...digging down to the bottom of the stairs and then make the decision to either reseat the steps I have, or replace them if they are broken. Set the steps more solidly than before, repack the dirt and get the whole thing ready to repour concrete.
    I guess Im looking for ideas, thoughts, or reasons to continue/stop this current plan.
    Added a couple pics in case it helps.
    Anthony
    18X36 IG Vinyl Grecian ~26K gallons
    Unidentified pump, Pentair Quad DE 100
    Sep 2009
    Bellmawr, NJ
    31
    Re: Pool repair
    Destruction began a couple hours ago.
    Would love to say that my mighty sledgehammer make quick work of the concrete...but it didnt.
    Honestly was nowhere near as much fun as they make it look on tv...but I did make progress.
    Broke up the concrete around the steps to see how much dirt was washed out.
    I expected a lot more washout than I found...but I guess it was still enough to cause the damage.
    After taking another look at the steps, I dont think I will have to reset them after all.
    This makes me much happier.
    Have a bit more concrete to take out, cut some straight lines...and then I can work on backfilling under the steps.
    Thoughts on what backfill makes the most sense?
    Open to other thoughts and suggestions.
    Anthony
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Pool repair
    Wow, Anthony! When you said you were looking for thoughts and suggestions, I thought you meant you had plenty of time! Well, let the demo begin
    I wish, for you, that the demo had been more fun Sure looks like fun from here
    Looks like you got a good start today and some of our builder folks will be along with their input.
    You're done SLAMing when:
    Sep 2009
    Bellmawr, NJ
    31
    Re: Pool repair
    Quote Originally Posted by Butterfly
    I do have time...but figured either way the concrete would have to come up. That and Im really looking forward to getting moving on this.
    Promised the wife I would make progress...so
    So far from done...
    Anthony
    Sep 2009
    Bellmawr, NJ
    31
    Re: Pool repair
    Getting closer to swim season...and the kids are growing impatient...
    Getting back to work on the pool...err, hole in the ground.
    I am ready to order a liner, but need to get my measurements first.
    Decided to empty the pool, bucket out whatever water was in the bottom and cut out the old liner.
    The old floor has some issues. Cracking along the sides...tap on em and it feels hollow...thoughts? Im guessing Ill have to break up anything that isnt solid and reapply.
    Main drain...I see one. Is this a safety issue? Never a better time to do something than now.
    If I am correct, the plumbing looks to T the main drain and skimmer together underground. That sound right?
    If that is right would that help to eliminate the safety issue associated with one drain?
    Any other thoughts welcome.
    Thanks!
    Re: Pool repair
    Anti -entraptment drains I believe are required , if you renovate a pool as you are doing. There are members of this site that live around you and deal with construction, They could perhaps offer some advice.
    coloeb,
    20k gal. IG fiberglass/plaster rectangle 32'x16'
    Hayward Superpump 3/4 H.P. primary Hayward model 5060 Booster Pump
    Hayward Pro Series High Rate Sand Filter
    Pentair Model 320 automatic Chlorine/bromine in-line feeder
    Sep 2009
    Bellmawr, NJ
    31
    Re: Pool repair
    I did some research on the anti-entrapment drains and it appears this one is already in compliance. From what I found the idea is to no longer have a flat plate on the floor...but instead to use a domed cover making it much more difficult for someone to form a seal across the whole face of the drain.
    Either way, I am thinking of adding a second drain...this would be the easiest time to do something.
    My concern is the plumbing underground. Im thinking that the skimmer and main drain are plumbed together. If they are and I add a second drain in the floor will this reduce the effectiveness of the skimmer? I know Im not changing the size of the plumbing, or the power of the pump...but Im not sure if there will be a reduced amount of flow through the skimmer.
    [attachment=2:w0em5mbc]photo 2.jpg[/attachment:w0em5mbc]
    Ok, using all the resources at my disposal I managed this overly professional diagram of how I think the pump works.
    Thinking:
    In to the pump through the red line. Depending on position of the black handle at the top the water will then either go the green route to waste or the purple route to the filter. After the filter all water goes to the yellow to feed the returns.
    This look right?
    I have 4 returns on the pool...but only 3 return lines. Guess there is no way of knowing which two are T'd together?
    One last shot in the dark. I cant read any writing on the filter (besides the brand) or the pump. Anything here look remotely familiar? Thoughts on where I can go to find out what these are...besides antiques?
    Anthony
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    Re: Pool repair
    Wow.
    Have you, by any chance, ever seen the Tom Hanks movie, "The Money Pit"?
    Sep 2009
    Bellmawr, NJ
    31
    Re: Pool repair
    Quote Originally Posted by Richard320
    Wow.
    LOL I have...but expect when its done it will be worth it.
    Most of the floor is solid...patch what isnt.
    Buy a liner and hang it.
    Fill with water.
    Cuss at the plumbing leaks.
    Swim.
    Think that should cover most of it
    Anthony
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Pool repair
    Welcome to TFP!!
    This is a game I've played many, many times and will certainly help with the project. Time's a little tight for me at this time of year, but let me tell you a couple quick things.
    1) Pressure test the lines ASAP!! - while everything is as exposed as it is now - if you find a bad line, it'll be a LOT easier to fix!
    2) A second MD can be added to comply with VGB ( ) - there are a couple different ways to do it & you'll have to wreck part of the floor, so more patching
    Tell us what you plan and feel free to ask any more questions
    Luv& Luk
    -Ted
    Sep 2009
    Bellmawr, NJ
    31
    Re: Pool repair
    Quote Originally Posted by waste
    Welcome to TFP!!
    Thanks for the advice.
    I finished measuring for the liner yesterday. Faxed that to the company for a quote. Now I have a bit of time before the liner comes...so will get to work on other stuff.
    Based on the above recommendation I will work on pressure testing the plumbing today.
    Thinking I can plug 2 of the 4 returns, pressurize the 3rd and put a guage on the 4th. That make sense or am I missing something?
    Not sure how to test the main drain/skimmer. I believe they are run together. Ideas on how best to test this?
    I will do what I have to for the MD. I figure I can dig down and find the original plumbing. Cut back some and piece my own new line with drain across the bottom.
    Thanks again,
    Anthony
    esim13's Avatar
    Oct 2009
    Denham Springs, Louisiana
    320
    Re: Pool repair
    Just wanted to say Hi and wish you lots of luck. I can't wait to see the finished product.
    10,408 gallon, 21' round, 52 in' deep AG, half in ground
    Artesian Clear Master Plus Sand Filter, Artesian Turbo King 2 hp pump, installed June 08
    GEAUX TIGERS!
    Pics taken 2012
    http://i941.photobucket.com/albums/ad25 ... CN0606.jpg
    http://i941.photobucket.com/albums/ad25 ... CN0607.jpg
    Sep 2009
    Bellmawr, NJ
    31
    Re: Pool repair
    Took a look at the plumbing last night. Figured out (sorta) what I would need to plug up lines and try to pressure test the system. Went to the store to buy parts and came home empty-handed.
    The best I can tell I will have to test the system as two pieces.
    1. skimmer, main drain, and plumbing up to the pump basket where I have to find a plug that fits inside the pump basket.
    2. 4 return eyes, plumbing back to the filter and the plumbing both underground and at the filter plus find a way to plug each of the yellow arrows in the pic below.
    I ran into problems trying to test option 1 because none of the three locations (skimmer plumbing, main drain plumbing, pump basket plumbing) are threaded. I can try to find plugs for each of them, but wasnt able to find a plug that I could run pressure through. I had no way to pressurize this half of the system.
    With #2, the issue was my inability to break the system into smaller pieces. I guess I could plug 3 of the 4 returns with 1.5" plugs. Then find rubber plugs to take care of the yellow arrows below. If I had that I could build some sort of contraption to pressurize the system with a gauge.
    Using my professional MS Paint skills I wanted to run an idea past ya.
    [attachment=0:2dby1zus]photo.jpg[/attachment:2dby1zus]
    Would it make sense to pick up some valves to fit inline at 1, 2, and 3 in the picture?
    If I did this I could test each line independently.
    Im trying to convince myself that it makes sense to do this because I will have control over the return flows later on. Is that important at all, or just a waste of time?
    If there is a better/easier way to test the system...please let me know.
    Anthony
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,379
    Re: Pool repair
    Definitely add valves! I don't know if they will help you test the system but they are needed so you have a way to cut off the water in the future for maintenance and repairs.
    Love TFP? Become a
    TFP Supporter!
    Sep 2009
    Bellmawr, NJ
    31
    Re: Pool repair
    Quote Originally Posted by zea3
    I agree completely...so I added valves.
    Decided to pressure test the underground plumbing prior to worrying about the floor or liner.
    Came up with a plubming contraption...and it seems to work fairly well.
    Tested the return on the steps and it held just fine. The step return is controlled by the first valve on the pool pad.
    [attachment=1:1kcq3ubg]photo 4.jpg[/attachment:1kcq3ubg]
    Moved to the next return and it held fine as well...this was controlled by the second valve.
    Heres the problem. I have two more return eyes, but only one more return line coming out of the filter.
    I tested the fourth return eye (closest to the diving board) and expected that return to be tied to the third return eye.
    I was wrong. It is self-contained.
    So I then moved to the third eye...plugged in the plumbing contraption and turned the water on.
    Sounds like the water is running...but I cant tell to where. Im not building up pressure on the gauge.
    [attachment=0:1kcq3ubg]photo 2.jpg[/attachment:1kcq3ubg]
    Anyone have any ideas where this line (with the green hose attached to it in the above picture) might go?
    Anthony
    Sep 2009
    Bellmawr, NJ
    31
    Re: Pool repair
    I guess I figured out the line in question from above. I left the water running a while and sure enough I ended up with wet spots around the pool...must be leaking underground.
    I have three additional returns, so unless someone explains to me why it would be real stupid to do...I will just cap off the offending plumbing and pretend it isnt there at all.
    One more line to test (as soon as I get the right size plug to test it).
    Anthony
    Sep 2009
    Bellmawr, NJ
    31
    Re: Pool repair
    Made some progress on the pool.
    Got all the old liner out of the pool and bagged it all up.
    I had about 4" of dirt on the shallow end of the pool...guess this was where the dirt that was supposed to be under my steps was washing out to.
    [attachment=2:544hckaq]photo 2(1).jpg[/attachment:544hckaq]
    Broke up and removed all the bad pool flooring. Patched that.
    [attachment=1:544hckaq]photo(1).jpg[/attachment:544hckaq]
    Hung the liner this morning and it is filling as I type this.
    Even have my assistant helping out.
    [attachment=0:544hckaq]photo 2.jpg[/attachment:544hckaq]
    Anthony
    esim13's Avatar
    Oct 2009
    320
    Re: Pool repair
    Looking good!!
    GEAUX TIGERS!
    Pics taken 2012
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    Re: Pool repair
    Great Job!
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
  20. Back To Top    #20
    Apr 2010
    Buckeye, AZ 85326
    619
    Re: Pool repair
    Awesome job and great write up. Time to kick back and enjoy a frosty beverage!
    11,872 Gallon IG Shotcrete play pool
    Blue Granite Pebble Sheen finish
    Hayward SwimClear c4025, Navigator & Tristar 1.75hp pump
    2' Powerfall
