Thread: Coping issue for inground pool.
    I have a 10 year old inground pool that is enclosed with a sunroom. A few years ago I noticed some small areas on the coping were blistering. The condition has continued and I'm now trying to figure out what to do about it. I have attached a photo showing what some of these distressed areas look like. I could use some thoughts as to what can about it.
    Some general info:
    Location is Chicago area
    Water chemistry is good. We did however have an issue a few years ago with pool center that messed up up water balance and had to drain the pool.
    Size is 16x32.
    Thanks for any help or insight on this issue.
    [attachment=0:2sp36v95]Pool coping 2.jpg[/attachment:2sp36v95]
    [attachment=1:2sp36v95]Pool coping 1.jpg[/attachment:2sp36v95]
    Butterfly's Avatar
    South Carolina
    Re: Coping issue for inground pool.
    Hi mikeT and welcome to TFP
    Because your inground pool is enclosed in a sunroom, it could and/or would be considered an indoor pool which puts a different twist on things.
    Please post a full set of water test numbers and give all the info included in this article.
    Also, if you have some pics of the overall set-up, including the sunroom, it could prove very helpful.
    Folks will be around soon to give you some ideas
    You're done SLAMing when:
    South Central NJ
    That looks like acid ate it. I suppose you could fill it with an epoxy filler, sand it smooth and spray paint it with Rustolium.
    Owner of - PoolGuyNJ LLC
