Thread: Calcium Deposits
    tagprod's Avatar
    Jul 2007
    Tomball, Texas
    Calcium Deposits
    Is it inevitable that even with a properly balanced pool, you will still get white calcium deposits from time to time? What's the best way to get rid of them. I've used a muratic acid mixture in the past, but I'm a little concerned about using too much of it on the same areas. It's always the same places - where the spa spills over into the pool and where the sheer descents are located.
    20K IG Gunite w/ raised 7ft spillover spa. 1.5 HP Hayward Northstar pump 425 sq ft Hayward cartridge filter, Colorlogic lights AquaRite SWG AquaLogic PS-8 control
    1hp pump for sheer descent
    I use a mixture of tile soap and muriatic great! (You can get tile soap at most pool supplies, it comes in 1 gallon jugs)
