Thread: Leveling a Used Hot Tub
    I just bought a Sundance Denali (4yrs old) from my neighbour. I moved it from his deck to my perfectly leveled patio. I now noticed that with the tub empty it rocks about a 1/2". I have double checked that my patio is perfectly level. I have also checked his deck and it wasn't bad.
    Now do I try to shim the hot tub to prevent the movement, problem being that I can only shim the edges.
    or
    Fill it and hope the weight of the water adjusts the hot tub to match the level patio?
    Jamie
    45,000 litres, IG plaster, Sand filter, ionizer
    Re: Leveling a Used Hot Tub
    That's what I would do using a long level on top rim on all four edges (if square shell) to get a feel for where the water level will be after fill.
    Barry
    Sundance Hot Tub 365 gal, acrylic
    (2) 2.5 hp pumps
    ozonator
    Northwest Ohio resident
    Aug 2009
    North Central Texas
    1,358
    Is the spa surround wood with wood supports inside? I'm wondering if, in a short time, dampening the wood, if applicable, if it will just settle in and level on its own?
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    I ran the level all the way around the top of the Tub. The tub is circular and perfectly level all the way around. It is a round tub and the "warpage" has caused 2 opposing sides to lift 1/2" from the decking. Hope thats clear enough. I am thinking I will fill it and cross my fingers hoping that it levels out properly.
    Jamie
    Feb 2010
    Houston, TX
    271
    It will probably level out when you fill it.
    HOWEVER - if it is warped at the top where the lip of the tub sits on the wood, there is a slight chance that it will crack when you fill it and it starts to settle. I would watch it carefully when filling and for the next few days, to make sure there is no cracking anywhere, just to be sure. If you notice any cracking, drain and shim anywhere necessary to keep it stable.
    I had the same issue when I first got mine, two opposite edges were slightly warped. The previous owners had someone build a cabinet for it, with the only support besides the corners being 2x4s running under the lip from post to post. I built a cabinet with plenty of support, made sure everything was completely level (except for those 2 corners which I hoped would level out. It was only warped about a quarter inch, and when I filled it, everything leveled out nicely...except that at one of the corners I ended up with a half inch crack. I marked the crack so I could check to see if it got any bigger, and it hasn't.
    Sorry for the long post, but I thought I'd share what happened with me. If the lip of the tub has been warped for any length of time, when it settles down, it can put stress on other sections and crack. Just keep an eye on it and it should be fine.
    By the way, welcome to TFP!
    John
    24' round Vogue AGP 12,000 gal. Flotec AT251001-01 1HP pump, Hayward S310T2 sand filter, Aquarite SWG T-15
    TF-100 (found at TF Test Kits) with Speedstir and Samplesizer
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,659
    Quote Originally Posted by 67ghiaTIV
    or
    Jamie
    Forget shims. Spray some Great Stuff foam under there and let it fill in the voids. Did it under a bathtub instead of a pile of mortar, and it worked great. Plus it insulates!
