Page 1 of 2 12 LastLast
Results 1 to 20 of 24
Thread: Pump motor question
    no-mas's Avatar
    Jun 2008
    FL
    405
    Pump motor question
    I had an engineer tell me he runs his pump around the clock because "the worst thing you can do for your pump is to turn it on." I get his point, namely the wear and tear of starting as opposed to continuous running, and he says he has replaced the pump 3 times in over 30 years. Seems impressive, but I've often thought "yeah, but you spend a fortune running that 2 hp pump around the clock."
    My question: is this b.s., or does it really last longer? How long should a pump motor last? Is it more cost effective to run a two speed motor on low speed around the clock, and therefore not have to replace it as frequently??
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Guest
    Re: Pump motor question
    Here's another thought, based on that statement: What if you only had a 1/2 HP pump (or a 2 speed/multi speed) pump and ran it 24/7? Now the cost to run drops immensely, and your water is never stagnant? I've posted many times before that I have a problem with short (2-3 Hour) run times, as pools sit stagnant for 20+ hours at a a time (which kinda grosses me out!).
    His theory (to me) makes some sense. I like water to be in motion, I just don't like to pay too much to have it do that! I can see the value of it though.
    South Central NJ
    3,192
    It's true. Starting electric motors is the toughest part of it's life.The sudden start stresses the bearings and the jump in current is tough on the components like the coils. Once it's started, the current settles down.
    Scott
    Owner of - PoolGuyNJ LLC
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by simicrintz
    Yeah Bruce, this is exactly what I'm getting at. I run my pump longer than I have to, if only because when I'm home, I want to see the water moving. And, running on low I anticipate a cost savings, especially over the summer.
    How long should a motor with 1 start/stop per day last, as opposed to running 24/7? Theoretically, is switching speeds causing the same wear as turning off and on?
    mas985's Avatar
    Pleasanton, CA
    11,742
    Turning on and off a motor may shorten the life of the motor but the energy cost you save by turning it on and off will likely pay for several new motors over the life of the first motor.
    Mark
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    What would the stress be like on a two speed pump that runs on high for pool cleaner/waterfall etc and then drops down to low for the rest of the time? Basically the pump would never stop but would cycle between the high/low speed.
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    mas985's Avatar
    Pleasanton, CA
    11,742
    I wouldn't expect much stress in either case. Is it more than not doing it? Yes., but not much. For higher HP motors > 10 HP, I think starting and stoping makes a much bigger difference but pool pump motors are quite small and the loads are not all that significant.
    Mark
    Aug 2009
    North Central Texas
    1,358
    My new pump has only been in for a week; have had a 2.23 hp, one speed, for 23 years. When my old pump(s) started up it started with a surge. The Pentair Intelliflo VF, doesn't do that and primes it up slowly, so there is hardly any "jolt". You can set the prime time. Do any of the newer pumps, other than the Pentair VS/VF have that feature?
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    mas985's Avatar
    Pleasanton, CA
    11,742
    I think that can only be done with a variable frequency drive so all of the variable speeds should have it.
    Mark
    22,553
    All variable frequency drives have the soft start feature designed in. You can buy an add on soft start for any motor but it's usually too expensive to be a benefit for the normal consumer.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by mas985
    No doubt this is true for a larger motor, but what about a low power (1/2, 1/3 or two speed on low) motor?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,058
    I have to wonder about whether the wear is that significant. I work in a garage, and our air compressor starts and stops all day long. I worked in the last shop for 14 years and we never changed the motor the whole time I worked there. It was capacitor start, if that makes a difference, but still, it had a rough life starting every ten minutes or so.
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    Most of the small pump motors are split phase, not permanent split capacitor. The start winding is controlled by a centrifugal acting, spring loaded switch. If the motor speed is modulated below the switch off speed the start winding will be toast pretty soon. Adapting a split phase motor to variable speed is not very practical.
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Not anymore. Most of the pumps today are PSC motors. Look through the pump list on the CEC web site and close to 2/3rds are PSC.
    Mark
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by Richard320
    Good point, Richard.
    Thanks to all...
    Feb 2009
    360
    Not to belabor a point, but having a start capacitor does not a psc motor make. It certainly improves starting torque, but if it is wired with the start windings without a corresponding run cap then odds are good it's a s/p. I would expect motors 1hp or less costing under $225.00 are likely to be s/p. (I was a small motor specialist for GE's largest fractional hp oem for many years.)
    mas985's Avatar
    Pleasanton, CA
    11,742
    Quote Originally Posted by Snark
    I wasn't talking about all motors just those used for residential pool pumps. They seem to be going the PSC route. If you don't believe me, check the California Energy Comission list of Title 20 pumps. They have each pump tested by a third party who supposedly is an expert in the field. Each pump motor is identified by it's type and performance. Nearly 70% of the pump motors are identified as permanent split capacitor motors. I haven't personally checked each pump but I'm pretty sure that the list is fairly accurate but if you have data indicating otherwise, I would interested to see it.
    Here is the web site:
    http://www.appliances.energy.ca.gov/AdvancedSearch.aspx
    Mark
    Feb 2009
    360
    PSC's are generally more efficient than s/p's (for simple centrifugal pump applications) and certainly more compatible with motor controls. It doesn't surprise me that California would be emphasizing (if not requiring) psc's as well as full blown controllers. While I don't have current industry data, prices and efficiency awareness are two big factors in deciding which motors are actually being purchased. While California typically pushes industry simply because of market size it usually takes several years for the rest of the county to follow. $.08 per kwh provides less incentive than $.27+ per kwh plus additional demand charges and power factor penalties. There hasn't been a power plant built (or substantially increased) out there in 20 years. Certainly the future is in controlled psc's, or actually fully controlled rare earth permanent magnet dc motors. But it won't happen for a while yet. As for me, I'll stay over here close to the Atlantic.
    mas985's Avatar
    Pleasanton, CA
    11,742
    If you look at the pump list on CEC web site, you will see that it contains nearly every pump currently marketed by Hayward, Jandy and Pentair/Sta-Rite so it isn't just the pumps "pushed" by California. There are currently ~194 pump models listed which I would say is pretty representative of the entire industry.
    Mark
  20. Back To Top    #20
    no-mas's Avatar
    Jun 2008
    FL
    405
    Swapped my single speed motor for a two speed this weekend; so far so good. The new motor is MUCH quieter on low speed, yet still moves enough water to sufficiently skim, run 3 sheer descent falls, run the heater and SWG. Easily the most difficult part of the switch was step 8 of this guide - installing the new seal to the seal plate. All the rest was as straightforward as could be.
    Now my question: What are the possible results of the motor NOT being grounded? My new one is, previous one was not. The square flange was corroded quite badly after less than 3 years, and while I see evidence of a slight leak, I'm curious whether the lack of ground could have contributed to the corrosion.
    Thoughts?
