Thread: Solar Heater Diverter Valve Question
    Feb 2008
    Northeastern North Carolina
    A little help please. I am trying to install a 4x20 Solar Heater on the garage roof next to the pool. Height is only 7 feet and garage roof is only 1/12 pitch so I want to mount the panels flat to the roof. As well I am hard piping it in and I was planning to mount the valve about 3 feet up the wall. This will leave me some room to install the SWG cell when it arrives. I need the valve so I won't use the panels at night. A 2-way valve came with the kit. However, the instructions seen to suggest installing the 2 way between the lines "going to" and "coming from" the heater which makes sense to me. My concern is: It seems to me that with the 2-way valve installed between the lines either up the wall or on the ground it will allow for the panels to bleed off when I open the valve thus having to reprime the panels daily. Question. Is my thinking of bleed off correct, is there a better location to install, and should I think about a couple of check valves to help? Thanks in advance for the help. Dave S.
    18'x52" AGP, 8500 Gal(approx), Hayward 1HP -2 spd pump, 200lbs sand filter, SWG on the way, Solar Heater in the works.
    Re: Solar Heater Diverter Valve Question
    Hot Sun Industries has some great diagrams of the best way to plumb solar panels.
    You want the panels to drain down any time the pump is off.
    Nov 2009
    Indialantic, FL
    Using the link Jason provided, I would pay some attention the the discussion about a diverter valve. I say this since you propose only a single panel (low GPM flow needed) and also want a SWG (which may need more flow). A diverter will split off some water to the solar panel, then the flows can rejoin before the SWG.
    Geometric 16X36', 16K gal, shotcrete, exposed aggregate plaster, acrylic coated concrete deck/cantilever coping;
    Pentair equipment suite (EasyTouch w/wireless, 2 Intellibrites, Intelliflo VS-3050, C&C 200 Filter, IC-40 SWG);
    Heliocol solar panels, Rocky's Roller, Blue Diamond robot
