Results 1 to 11 of 11
Thread: No pressure and dirty pool
    I just bought a home with a gunite pool; very simple set up with only one valve and a cartridge filter. Upon advice from the pool supply co., I have: replaced cartridge and the o-ring in filter basket. Pressure is at maybe 2 PSI, and there is churning water in the basket and pressure coming out of the returns but apparently lots of air too. Every time I start the pump, I do have to bleed air out of the top of the filter. Suggestions? Thanks!
    Jul 2009
    Seattle, WA
    89
    Re: No pressure and dirty pool
    Does the pump ever flush all of the air out of the basket?
    If not, then you either need to add enough water to the pool to bring the level up high enough that the skimmer stops sucking air or you need to start looking for a suction side leak.
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
    30,432
    Yep, Grape Ape's got it.
    If the water isn't sucking air thru your skimmer, it's sucking it somewhere between the skimmer and the pump. The most common place is the o-ring in the pump basket lid.
    I've replaced the o-ring in the basket, and now I don't have to re-prime it every time. Pump is not a two-speed. But I still have to bleed air out of the top of the filter every time (maybe I don't need to, but there is always lots of air in there). Still no pressure. Hard for me to tell, but it still looks like some air circulating in there with the water, and also out of the returns.
    mas985's Avatar
    Pleasanton, CA
    11,742
    If you have to constantly bleed air out of the filter, it is getting sucked in from somewhere.
    Mark
    South Central NJ
    3,192
    If the pool level is 1/2 up the skimmer, check the flapper (proper term is weir) and see if it's stuck. If it's free floating and the skimmer body is full, the suction side plumbing has a leak or is clogged. Post a picture of the pump and suction plumbing at the equipment pad.
    How do you add chlorine?
    Scott
    Owner of - PoolGuyNJ LLC
    Quote Originally Posted by PoolGuyNJ
    Scott
    I take some pics this afternoon and will check the flapper. Chlorine is dispensed via a floating dispenser. I do believe now that there is a leak on the suction side, but wouldn't that cause water leaks too? Can't find any and the pool holds water just fine and is full. Thanks for your help.
    mas985's Avatar
    Pleasanton, CA
    11,742
    Suction side is under fairly high negative pressure so when the pump is on, it will suck air. When the pump is off, it may not leak water.
    Mark
    South Central NJ
    3,192
    Or the air leak is above the water line. That being the case, the likeliest locations is what ever is threaded in front of the pump.
    Scott
    Jul 2009
    Seattle, WA
    89
    Tex,
    Can you clarify, once the pump gets running is there still air in the basket? It is okay if it takes a couple minutes to blow it out, but it should settle down to just water.
    South Central NJ
    3,192
    If the water in the pump doesn't seem to be moving with an expected amount of movement, a clog is still a possibility. If the fitting in front is tight, it's likely a clog of some sort, be it debris or a collapsed line.
    Scott
