Results 1 to 9 of 9
Thread: Pool Timer
    Pool Timer
    This will be the third year of having my above ground pool - so far I just have had the pump wired to a switch in my garage which I'd have to remember to turn on and off each day, and with my work schedule forgot half the time. I'm looking for some sort of simple, inexpensive 24 hour timer which a manual On/Off switch for if we use the pool during times the pump isn't scheduled to run, I can switch it on without interrupting the timer schedule. The line from the breaker box is dedicated to the pump only, on a 20Amp breaker. I'd also like this to be a hard wired timer I can mount on the wall inside my garage. I really like the Mechanical Time switches (like the hot water heater timers) but I can't seem to find any 20Amp ones with a manual On/Off switch.
    Anyone have any ideas?
    Thanks.
    Feb 2008
    Denton, TX
    5,061
    Re: Pool Timer
    Does anyone else think that a simple Intermatic timer would be the ticket here?
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: Pool Timer
    I sure do! Don't know the model numbers, but what I have is as basic as it gets, and would fit the bill. It's just a pretty basic intermatic clock timer.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Feb 2008
    Denton, TX
    5,061
    Re: Pool Timer
    Here you go...
    http://swimmingpooltimeswitch.com/CD-104P.html
    Not saying that this is where to buy it or anything, but this is the simple Intermatic Mechanical Timer.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Re: Pool Timer
    That's the timer we have. Two ON/OFF tabs and a manual override. We've only ever used one ON/OFF setting, haven't had a need for two. It runs during the night hours. When we swim in the afternoons I flip the lever to ON and then either just leave it running or I turn it back off when we're done. It's a very handy gadget.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,045
    Re: Pool Timer
    Quote Originally Posted by 257WbyMag
    That's the ticket.
    The picture omits the fact that there's a cover over those bare terminals after you get it all connected.
    Re: Pool Timer
    I have timer that i bought from lowes.
    Something like this, just make sure it will carry the AMPS of the pump motor.
    http://www.lowes.com/pd_155550-207-T...=timer$y=0$x=0
    K HOLMES
    23 X 45 GUNNITE
    OWNER/BUILDER
    May 2009
    Jasper, TN
    249
    Re: Pool Timer
    Quote Originally Posted by Richard320
    That's the ticket.
    So you would have to cut the plug from the end of the cord and wire it to those terminals?
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    New2Me's Avatar
    Jun 2008
    SW Indiana
    322
    Re: Pool Timer
    Most pumps for AG pools are 110v, and don't need 20 Amps. I would be concerned if you have a 20A breaker wired to 14 G wire, that is a code violation (and a fire hazard.) Most light switches are only rated for 15A, as are most duplex outlets.
    You should be able to find an in-expensive 15A timer, especially if it is in an indoor location. The simplest moving clock-face tripper light timers ($5) are rated for 15A, and most have a manual on/off wheel. Same principle as the intermatic ($60) pictured above.
    Good Luck, and Best Wishes!
    22 x 40 IG vinyl lined, 23,570 gal.
    1 hp. Pac-Fab Challenger pump 300# sand filter
    Intex 8110 SWG, Hayward CL220 offline feeder
    Hayward 250K Btu gas heater
    Aquabots
