Page 1 of 5 1234 ... LastLast
Results 1 to 20 of 85
Thread: New Pool Owner looking to Learn...Where to Start?
    Hello everyone,
    I'm a new User here, A new Home Owner, and A new Pool owner. I'm here to learn and get the help of some Pool Guru's like everyone here. Many questions will be asked I'm sure... I'm also a fish keeper so I'm somewhat familiar with testing and adjusting water parameters but not with a pool.
    I've got a house in Wisconsin that came with a in ground pool. I'm basically a noob to this so I'll be looking for your help and guidance. The pool has not been opened for the last 2 years. I has had a cover on it and it is still pretty full. The water is obviously very dark and very smelly. I've yet to determine the size gallon wise because it's a strange shape. I've got to do some measuring and then I'll get back to everyone.
    What i know about the pool: It's in-Ground and Cement. Deep end is roughly 8 feet and shallow is 3. The top edge is tiled. I've got a diving board. It's not been used in 2 years. Pump and filter look in good shape (Laser Jacuzzi 225 filter). Pool is unheated. Pool has been holding water
    So obviously it's too early open just yet especially if it's unheated and spring maple whirlybirds haven't even started to grow. I just need to know where to start. Anyone have any links to read for super beginners?
    I don't have any maintenance items...what should i get? I know I'll need to get a water test kit to see where the water before it's determined it needs to be drained or not. I'll need a net to clean up the **** and start cleaning what I can.
    Here are some photos of the pool last summer. So it's a little dirtier since then. As you can see, I've got some work to do.
    23000, Sand, IG, Plaster, Century Pool/Jetted Tub Motor 1.5HP, Rainbow Lifegard Feeder Model 300
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New Pool Owner looking to Learn...Where to Start?
    Welcome to TFP!
    Have you read Pool School yet?
    I think you have a pretty good idea of where to start, you'll need one of the recommended kits, read about them in Pool School.
    You'll need some equipment to start clearing out the gunk. Have you seen our Visual Encyclopedia?
    Then you're going to need lots and lots of chlorine, if you can find a source for reasonably priced 12.5% you'll haul less jugs. Otherwise Wal-mart usually has the best price at $2.54 for 182 oz of 6%.
    Chances are slim your water will have any CYA after sitting dormant for 2 years. So during part of the shock process you'll be able to use Dichlor as a way to quickly raise CYA, killing 2 birds, yada yada.
    Edit: hit submit too soon. Once you get the filter operational, and start clearing the gunk, you can get the water circulated and do your testing. The water must be circulating for several hours before you do your first test.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Start reading The Pool School. The link is right on top of the home page here.
    Order a test kit. Get the deluxe TF100, you'll need the large quantity reagents. Someone will post a link shortly, if they haven't beat me to it. Bookmark the pool calculator, you'll be using it a lot!
    Figure out the size of the pool. Figure out what equipment you have, pump & filter-wise and see if they work. You can't really do anything unless the water is circulating. Also figure out what all the valves do and where they go so you get proper circulation. I was getting none in my main drain until I spent about ten bucks on a diverter thing - looks like a flying saucer.
    You're gonna need a leaf net, a pole, at least one brush, a vacuum, and a hose. Also figure out where to connect the hose.
    Then load up on Chlorine and muriatic acid.
    GO!
    11,969
    Well, not everyone needs muratic acid. I've never needed or used it.
    Test results will tell us for sure.
    Richard is right, the TF100 XL is the kit you need, and gives you the most bang for the buck.
    http://tftestkits.net/splash-page.html
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    As you can see, you will get all the help you need here. After you read Pool School, post back any questions.
    Your place will obviously be beautiful when cleaned up and I can't wait to see the transformation!
    Don't forget to have your camera ready.......we love pics and just can't get too many!
    You're done SLAMing when:
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
    You gotten some good advice thus far. I can't wait to see what that pool looks like when you get it going again.
    Aug 2009
    North Central Texas
    1,358
    Beautiful place. I love your house. It looks like is was inspired by Frank Lloyd Wright.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    WOW thanks for all the quick responses. I'll start reading and purchase a few tools to get started. This is going to be a little daunting but hopefully sun will be enjoyed!
    I'm also interested to see what it looks like. I'll be sure to take a bunch of photos!
    The house was build by a Frank Lloyd Wright Apprentice...if you'd like to see more house photos I've got a blog with my details of work i'm doing. It's at http://www.usonianautomatic.com
    Casey's Avatar
    SW PA
    10,438
    Welcome! You've gotten great advice thus far!
    We will need lots of pics before, during, and after! We also need cannonball pics too so don't forget!
    Can't wait to see it complete!
    If that is a solid cover, you should get a pool cover pump, or setup a siphon, and get the water off the cover.
    It is also possible that the cover is either mesh, or has a mesh panel somewhere. If so, instead of removing the water, you should slowly increase the tension on the straps so the cover pulls up above the pool water and the water on the cover drains down into the pool. Doing this will probably require repairing any of the straps that are no longer anchored down.
    Ok, I'm done with school although I'll be referring back often...
    Jason,
    The cover is solid but the water level is up to this level in the pool. I plan on removing all of the debris and then simply removing the cover as there is much more debris below the cover. So is draining the water off the cover really necessary this time? I understand if you've got a clean pool below. Now that the snow melted around the deck i spent time re-anchoring some straps and adjusting some. There is still a good amount of ice on the cover that should be completely melted soon.
    My to do list:
    Read, Read, Read
    Figure out Equipment and specs
    Figure out if what i have works...this will happen in April sometime.
    Study my setup
    Research vacuums
    Research locations for chlorine and best prices
    I'll plan on getting some tools to get started including:
    TF100 XL
    Equipment Pole
    Leaf net
    Brush
    Vacuum eventually
    Hose
    anything I'm missing for now?
    Getting the debris off the cover will be much simpler than getting it out of the pool once the cover is off. It isn't required, but you will save some work clearing the cover as I suggested. The water level doesn't matter very much as long as there aren't any holes in the cover. If there are holes in the cover, attempting to pump off the cover will pump out the entire pool instead.
    For an anchored cover like that one, the water level on the cover and the water level in the pool will always be about the same as long as there is enough give in the anchors to let the pool water hold the weight of the cover over the winter (which is how it should be setup over the winter).
    How do i determine the gallons of my pool? Here is a diagram of the rough measurements.
    Dec 2009
    Central Massachusetts
    2,690
    Break it up into manageable rectangles then length x width, x depth.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Butterfly's Avatar
    South Carolina
    10,045
    ............and you can use Jason's Pool Calculator to help you with the calculations.
    Let us know what you get and others will chime in with their opinions
    22,548
    If those are your dimensions then that's an odd shaped pool. I drew it in CAD using them and I come up with about 23,600 gallons. I'm sure that's not perfect but it should be close.
    Ok it looks like it's roughly 26,300 Gallons.
    Here is my calculation chart....
    Jan 2009
    Cupertino, CA
    1,966
    When you chop up the area into sections, you can use different depths appropriate to each section. I don't know what your floor looks like so I guessed average 7' for the top two sections, 4' for the transitional triangle, and 3' for the shallow end:
    15x16x7x7.5=12600
    15x16x7x7.5/2=6300
    15x5x4x7.5/2=1125
    15x16x3x7.5=5400
    total=25,425
    These estimates are more-or-less in the same ballpark so I guess I've confirmed that we all passed the basic arithmetic test. You can go with whatever volume you feel good about.
    Another way to guesstimate your volume is a chemical test; add a known amount of something to the pool, and see whether it changes your levels in the way you expected. I can describe this in more detail if you like.
    --paulr
    BBB "Intermediate Swimmer"
    Purchased my TF100 XL today! Hopefully temps will start to warm so that I can get the cover off and start cleaning and eventually see if my pump works...then I'll test the water to see what needs to happen.
    Anyway here are more photos of the current state of the pool....
  20. Back To Top    #20
    Jul 2009
    Seattle, WA
    89
    Quote Originally Posted by wiscousonian
    If I were in you position, I wouldn't pull the cover off until I knew the pump worked. You're asking for algae if you let sunlight and whatever the wind brings by into your pool without the ability to filter and mix the chlorine in.
    You should also run the pump of several hours before you test the water. I just tested mine last week without mixing it up, got a scarily low CH reading but after I ran the pump for 2-3 hours the reading doubled.
    20,000 Gallon kidney sort of a sand filtered gunite in ground pool w/ hot tub.
