Thread: new filter shooting DE into the pool
    Hi-
    Brand new pentair FNS DE filter. Today when the pool filter started I saw DE enter the pool through the returns. what gives?
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    Re: new filter shooting DE into the pool
    There are three possibilities: there could be something wrong with the main valve that lets water through backwards, either it is set wrong or is leaking internally. One of the grids could be torn. Or it was not assembled correctly so there is a way through the filter that doesn't go through the grids. If you just had the pool built, you should tell the builder right away. Otherwise you should open up both the multiport valve and the filter and examine everything to make sure everything is put together correctly with all of the O-rings and other seals seating correctly, and that none of the grids are torn.
