Thread: Do I need to open my pool?
    Aug 2009
    Lafayette Area, Indiana
    25
    The pool turned green this weekend with visible algae growth on the bottom and sides. The answer seems to be that I need to open the pool and get chlorine in it, but is it too early? I am not sure we are past freezing weather and I am worried about damaging the pump. I have not tested the water and I am not sure if it would do any good to do so. Thoughts?
    AG 24' Doughboy 13,500 gallons
    225 lb Sand Filter, Intex SWG
    Royal Spa Emperor II 545 gallons
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Do I need to open my pool?
    Depending on how cold it is going to be getting over the next month or so IMO I would hold off opening your pool if you suspect you might still have freezing temps. I'm assuming you remove your filter from the pool for the winter season ?
    Your algae problem will be easy to clear up when the warm weather gets here so I wouldnt fret over it ...
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    If your pool isn't still frozen (like mine) you can always start dumping in bleach or liquid chlorine and mix it in either manually or by using a submersible pump to circulate it. It's probably not too early in the season to hook up your plumbing and run the pump and filter if you keep an eye on the temperatures and keep it on when it gets near freezing.
    I'm kind of surprised to see that there's enough algae growth to turn the water green this early in the year at your location. Add chlorine and brush what you can, and run the filter.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I agree with Anna, get some bleach in there and maybe rent a submersible pump if you don't have one to help circulate it. I opened April 8 last year, and I'm pretty far North of you, that's only in a couple of weeks. I would think you could open it and if they forcast especially frigid weather running the pump during that time should help prevent stuff from freezing.
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by frustratedpoolmom
    Renting, of course is one option, but you can find good submersible pumps for under and just a little above $100 US. I have no idea what renting fees are. My submersible pumps have really saved me or come in really handy for other uses too. I use them mostly for the pool though.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    11,969
    Alice, I do agree with you, I actually bought one for $89 last year and wondered why I didn't do it sooner! It came in handy when I needed to drain the water off my winter cover, made the task much simpler than our old manual way.
