Thread: With high TA should I add borates
    curious to know. Lowering my TA should be a ***** as my tap h20 is really high and with the heat evaporation I know im going to be adding water on a regular basis. I am balanced as long as i watch my PH. Can I still add borates without adjusting my TA?
    18,900 Stonescapes Tahoe Blue xtra black, 8 jet Spa, Pentair inteliflo VS , Pentair FNS 60 DE, Inteliclor40, Pentair 400,000 Mastertemp heater, 3 spillovers powered by a Pentair 1 HP whisperflo pump, The pool Cleaner, 2 Intellibright color changing lights and 400 sq ft. of Heliocol roof mounted solar.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: With high TA should I add borates
    Once you have borates in the pool it becomes especially difficult to lower the TA.
    Mar 2007
    San Rafael, CA USA
    12,082
    Quote Originally Posted by frustratedpoolmom
    It's more difficult because it takes more acid to get the pH down to 7.0 and the same length of time for aeration results in a smaller pH rise so it will seem as if progress is slower (it's not, but it seems that way). You still end up lowering TA as quickly as before, but the process isn't as obvious when you don't see the pH rise as quickly.
    I have a balanced CSI even with a high TA. The high TA occurs naturally with the well water that our city used. Would it be a bad idea to not lower the TA before I add borates. I just know that lowering the TA is going to be a battle and was curious if I cant just leave it the way it is as my CSI is balanced or should I give it the boy scout try.
    There is nothing wrong with maintaing fairly high TA levels as long as your PH does not drift up too quickly and your CSI level is under control.
