Results 1 to 7 of 7
Thread: TFTest Kit for soil PH
    billybrobob's Avatar
    Apr 2008
    NW Florida
    31
    Spring is in the air. Can I test my soil PH using my test kit?
    40,000 gal pool, Goldline SWG, 1.5 hp pump, sand filter, plaster w/epoxy paint.
    South Central NJ
    3,192
    Re: TFTest Kit for soil PH
    No.
    Scott
    Owner of - PoolGuyNJ LLC
    Apr 2008
    NW Florida
    31
    Thanks for the quick response.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by billybrobob
    I was thinking, "With which test kit?", but Scott must have known what you meant. The following links should address your question. The first one is a 'HOW TO' article, the others are pH soil tests you can purchase. No idea which test of the many available is better.
    http://www.thegardenhelper.com/acidsoil.html
    http://www.amazon.com/Soil-Tests-Nit.../dp/B0013WGEPY
    http://www.grainger.com/Grainger/ite...esting-_-4EVY4
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    Swimming pool PH tests are really only good between about 6.8 and 8.2, while soil PH varies over a much wider range (mostly lower). You could find out which side of the pool PH range the soil was on, but most likely you couldn't find out what the PH actually was because it would be out of range of the pool PH test.
    Apr 2008
    NW Florida
    31
    Thank you for the replies. My nephew was making deisel last year and asked me how to measure ph. It rolled into voltage vs. visual. Can't do visual test without clear water. My bad, no is right.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Your county agricultural extension office will do soil pH tests for you; I think it's still free in Florida. Look for your county office here.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
