Thread: Chlorine Levels
    Chlorine Levels
    I have a chlorine pool with vynil liner the base has developed lots of black patches.
    My chlorine level is high and the PH is low how do I reduce the chloine level
    25,000 Gallons IG dark bottom gunite/plaster
    Aqualink System with 1.0 hp pump and DE Filter
    Kreepy Krauly Pool Cleaner
    South Central NJ
    3,192
    Re: Chlorine Levels
    What's the pH, Alk, Free Cl, Total Cl, Calcium and CYA levels?
    A pic of the splotches helps. If they are hi res, a link to a photobucket account (free) will help.
    Scott
    Owner of - PoolGuyNJ LLC
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Chlorine Levels
    Hi Richard,
    Yep, as Scott said, we need more info.
    You can go to Pool School to help with the info needed.
    Also remember to add your location (city/state).
    If you do not have one of the Recommended Test Kits, just take the water sample to a pool store for testing for now.
    Without test results, we do not know if your chlorine levels are high or not. It is relative to your CYA levels.
    Lots of folks around here to help you get your pool sparkling and safe.
    Welcome to the forum
    You're done SLAMing when:
    Jan 2009
    Cupertino, CA
    1,966
    Re: Chlorine Levels
    Quote Originally Posted by Richard Farmer
    Normally the chlorine level will drop over time on its own. How high is "high"?
    A high chlorine level doesn't normally cause staining, that usually means other things are out of balance, which is why Scott and Butterfly were asking about those things.
    --paulr
    BBB "Intermediate Swimmer"
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Chlorine Levels
    Do you routinely use algaecide containing copper?
