Thread: Intelliflo Priming Error
    Hey there. Have an Intelliflo VF, worked pretty good for about 2 months. This week, got a lot of leaves in the pool from a wind. So, I ran it in manual mode for more flow to my pool cleaner. Also tried to run it in vacuum mode.
    Same problem each time, System would try to prime and keeps shutting off automatically after failing to prime. This happened even with the strainer for leaves is empty.
    Prior to attempting to vacuum, I had the system filtering for about 10 hours a day, then had it run for an hour a day in manual mode, at higher flow rate, for the pool cleaner.
    35,000 gal pool, Pebble-Tec, Pentair VF pump, DE filter, Aqua Rite SWG, Pentair Minimax Heater in Southern California
    South Central NJ
    3,192
    Re: Intelliflo Priming Error
    Air leak somewhere. Check the pump lid for the gasket. Check the skimmer weir. Check the baskets for cracks.
    Scott
    Owner of - PoolGuyNJ LLC
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Sounds like your Max Priming time is set too low. Try setting it for 4 min and see if that helps. A whisperflow mechanical seal can handle about 15 min before damage occurs.
    Factory Warranty Station for:
