Thread: Opening... do I need to change any of my numbers?
    triplets&quads's Avatar
    May 2008
    North Carolina
    79
    We do not cover our pool during the winter, but because of the extremely cold weather we had, we did drain all of our equipment instead of running the pump. Now our weather has been very mild and the pool water was starting to look dull, so we have started the pump running again, but not the SWG. Here are my numbers, so please let me know if I should add anything.
    Water Temp: 54
    FC 2.5
    CC .5
    TC 3
    PH 7.8
    TA 40
    CYA 50
    Thank you, and I am looking forward to another great season of beautiful water!
    I AM LOVING THE SALT WATER AND THE BBB METHOD! 15 yr old 15,300 gal ABG, with 5 yr old liner, 5 yr old AquaTrol SWG, S220T Hayward Sand Filter, 1 1/2 HP 2 speed Hayward Pump, TF100 Test Kit, 11 yr old grandson, 6 yr old grand-quads AND 4 year old triplet grandsons! ~ I AM HAVING FUN NOW!
    Re: Opening... do I need to change any of my numbers?
    Your TA is a little low, and if the water is above 50 degrees I would bump up the FC level up to 4. CYA is too low for use with a SWG, but that isn't important just at the moment.
    May 2008
    North Carolina
    79
    Thank you Jason!
    May 2008
    North Carolina
    79
    I forgot to ask... should I raise my TA, and if I do, what should I raise it to?
    30,431
    It seems to me that TA can be dealt with reasonably well at a pretty wide range. Like Jason, tho, I would suggest bumping it to about 70-80.....that's a good range for an SWG pool.
    You might do that test one more time before you do that.....make sure it was accurate the first time.
    When you raise it, do it with baking soda.
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by triplets&quads
    Recommended Level is 60 to 80.
    Since you appear to be up and running, I'd increase the TA.
    You're done SLAMing when:
