Thread: High Salt
    Jun 2008
    Bruce Peninsula - Ontario
    44
    High Salt
    I'm asking this question for a friend in Fl., they installed a SWG last fall it is working ok now but, last night they got a pile of rain and the SWG is now reading high salt, he has a second generator witch he put in and it still reads high salt, any thoughts?
    Thanks
    20 X 40, 28000 gal IG cement bottom, steel sides, vinyl liner, Pentair 4X160 pump, sand filter, SWG, Titan heat pump, coluorlogic and fiber optic. concrete-exposed aggregate deck
    1 skimmer, main drain, 4 returns ( 2 in stairs ) JEWEL LIKE WATER thanks to TFP!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: High Salt
    It would seem the rain would dilute the salt reading, not make it read high...
    I would verify the reading by testing with salt test strips or taking a sample to the pool store for them to test the salt level.
    Also it would be helpful to see a full set of test results JIC.
