Thread: New ColorQ results from the new(er) pool...
    Jul 2007
    North of Dallas
    207
    Been working on bringing the CH up and CYA. Little bit back, couldn't get it to maintain chlorine but now it's much much better Here are the results from the AquaChek yellow strrip and the ColorQ
    Test strip:
    FC - 10
    PH - 8
    ALK - 120
    CYA - ~80 (hard to read)
    ColorQ:
    FC - Hi (doesn't read over 10)
    PH - 7.7
    ALK - 126
    CH - 138
    CYA - 26 (not trusting this one)
    Before, it was all I could do to keep the FC at 1 with the swg at 100%. I worked for a week on the CYA then hit it with some cal-hypo to bring the FC up and it's been a high FC reading ever since (approx. a week with the swg at 85%) and the CYA on the strip sounds promising and it wasn't reading anything 2 weeks ago. Tonight, I added a half-gallon of Mur. Acid and turned the swg down to 65% to let it ease off some. I have to pick up some more CH+ tomorrow to bring it on up to the 240 range.
    My Pool - 18x24 fully setup Cabana, 22x48 gunite/quartz plaster (3-5-3 depth) & 8' spa w/ spill and 5' natural rock waterfall; Hayward DE filter/pumps/heater; Hayward Pro Logic controller; Phantom cleaner. Finished 06/01/07.
    RedishConstruction.com
    donaldm823's Avatar
    Cape Coral, FL
    147
    Re: New ColorQ results from the new(er) pool...
    Quote Originally Posted by sredish
    Test strip:
    FC - 10
    PH - 8
    ALK - 120
    ColorQ:
    PH - 7.7
    ALK - 126
    CH - 138
    The CYA reading on the colorQ is quite sensitive to outside influence such as temp, chlorine level, time since mixing and sufficient mixing of the sample. I have found better results, by crushing the pill in the test tube of water, then shaking the sample for 10sec, then waiting 5 minutes, then shaking again and measuring the CYA. Also the temp of the sample must be in the low 80 to ensure sufficient mixing. Since your chlorine is high, you may not get an accurate reading until it is down to the 5ppm range
    Don SW Florida
    10,000 gal in ground concrete pool
    Pentair Cartridge filter, Pentair SWG, Pentair Intelliflow VS pump (11018)
    FAFCO solar panels w/Pentair SolarTouch controller
    using BBB for pool chemistry/Lamotte ColorQ tester for daily testing
    Jul 2007
    North of Dallas
    207
    Quote Originally Posted by donaldm823
    Thanks for the response. I'm working on lowering the FC now, with minor adjustments to the swg, just don't want to make any big sudden changes. I usually, mix/crush the tablet and shake good, then let sit for 2 minutes then test, but mayby I'll give it more time, and I'm sure your right with the inaccuracy due to a high chlorine level.
    Anyways, thanks again for the response.
    Alberta, Canada
    177
    The CH test on the Color Q had some issues as well.
    They sent me new regeants and I am still having issues so they are having me return my tester to get it upgraded.
    They tell me their newest testers should say 1.22 when it first comes on.
    Anyway,just wanted to give you the heads up, you may want to test hardness with some other test just to be sure you don't bring it up too much.
    Deena
    http://www.lindbrookstargazer.ca
    100,000 liter IG vinyl liner
    Rolachem Chlorine & Muratic acid Auto feeders/Pool Perfect Auto feeder
    Pentair 30" filter (Tagelus) Sand filter/Centruion switchless pump 1.5/.25 HP
    Jul 2007
    North of Dallas
    207
    last night, i took another sample with the test strip and the CQ.
    In regards to the CYA, the strip is showing close to 80 or 90 and the CQ is showing 26 again, exact same as the prev. test. Granted, my chlorine is still somewhat high, i'm slowly backing off the swg to get it to maintain what i want but i'm about to turn it off for a day and let it come down quicker.
