Thread: Best valve actuator
    Oct 2007
    Valrico, FL
    Best valve actuator
    I would like some opinions on different makes of valve actuators. I have found the following models:
    1. Intermatic Pe24VA
    2. Goldline GVA24
    3. Pentair CVA24T
    It appears that the Intermatic unit is the lowest cost.
    7,500 gal, IG pool, L shape 22' x 15', 1.5 hp pump, cartridge filter, AquaPlus SWG/Controller, Pebble-Tec liner.
    South Central NJ
    Re: Best valve actuator
    You missed Jandy's JVA24.
    All are interchangeable.
    All last a long time.
    I use Intermatics often as replacements for the exact reason you cited, they cost the least.
    Owner of - PoolGuyNJ LLC
