Thread: whisperflow motor swap
    no-mas's Avatar
    Jun 2008
    FL
    405
    Hi folks. I'm about ready to switch the motor on my whisperflow to a two speed and am considering a tightwatt2 to control it. Anybody have experience with this timer? What are the intermatic 2-speed timers?
    Regarding the motor swap, any pitfalls to watch out for? I'll replace all the seals, o-rings etc, but haven't done one before - just want to see if anybody has caveats to share.
    Thanks for any and all input!
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Mar 2010
    17
    Re: whisperflow motor swap
    Well I replace motors as part of my job. Its not too hard at all. Make sure you replace your pump seal because this is 9 times out 10 why your motor went in the first place. I replace mine every year. If it goes it allows water to back up into your motor. Make sure when you install it, that you put it ceramic to graphite, or you will see a lot of smoke when you plug it in. If you have any questions about replacing your motor, just message me.
    1965 Hybrid Pool, Swimquip U3 skimmer, Aqua slide n dive board and slide, Hayward Super pump, Hayward sand filter.
    mas985's Avatar
    Pleasanton, CA
    11,742
    You will probably want a new seal kit as you can damage the old one removing the motor. The usually come with the shaft impeller seal as well as an impeller ring.
    Mark
