Thread: Bonding a booster pump
    Aug 2009
    North Central Texas
    I don't mean to hijack this thread but I do have a question about bonding (not grounding). When it comes up or is discussed I always see info about bonding the main pump and other parts of system. What about a booster pump or auxiliary pumps?
    If it occurs to you that you might be hijacking a thread, please start a new thread Thanks JasonLion
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Re: Bonding a booster pump
    Yes, everything that is either metal or electrical that comes in contact with the pool water or is located within a couple of feet of the pool must be bonded (at least for permanently installed pools).
