Thread: Fafco Solar Bear for IGP?
    I feel like I'm missing something obvious. I've found a good price on some 4'x20' Solar bear panels that I want to install myself, but I have a 20'x40' IGP and these are supposedly for AGP. The biggest IGP panels that FAFCO makes seem to the be the sunsaver which are 4x12 or 2x20. They are also more expensive.
    So.... what's the deal? Do I get the AGP panels, mount them to my roof and forget about it, or do I shell out some extra cash for panels that are explicitly designed for IGP? What's the difference, anyways?
    15.5 k gallon. IG. plaster. Pool/spa pump: Jandy Zodiac FloPro FHPM 2.0-2 (0.25 and 2.0 HP 2-speed). Water feature pump: Jandy Zodiac Stealth Pro Series, SHPF 3.0 (3.0 HP). Filter: 250 SF cartridge. Surface area 290 SF. Jandy AquaPure SWG and PureLink. Aqualink controls. Jandy Legacy Pool and Spa Heater by Zodiac 400,000 BTU - natural gas. Heliocol solar panels. Built 3/2013.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Fafco Solar Bear for IGP?
    AG panels are often made with a diverter so the inlet and outlet are on the same end of the panel, while IG panels have the water entering one end and exiting the other. AG panels aren't optimum for roof mounting for that reason.
    New Brunswick Canada
    819
    I have both here, and in my opinion, there is no difference, as long as you get the one with 2" headers, you will be ok.
    I have 3 on my patio porch roof, work like a charm, and no way I would ever put any heater other then solar, why pay, why use resources, when you can get it for free.
    *** I couldn't find any forum rules about directly linking to products - if this is against the rules please let me know and I'll take down ASAP ***Fine. JasonLion
    Ok, so I'm looking at buying this:
    http://www.aquasuperstore.com/produc...ount~3659.html
    I have an 800 sq ft pool and put these on the south side of my sunny Las Vegas house, so I'll I'm looking at buying 6 packs of these (2'x20' x 12 = 480 sqft, which is 60%, the min recommended for a south facing roof)
    For a controller I was looking at this:
    http://www.aquasuperstore.com/produc...LAID=327034108
    Other than that, what do I need? Seems like perhaps I should get one these so that I get the systems kit:
    http://www.aquasuperstore.com/produc...LAID=327034772
    Although it says it has 1.5" headers, which doesn't seem right. I'm just worried I'm going to end up heading to my pool supply store and spending $300 on valves and what-not that I could have just gotten with the system's kit. I already have 2" PVC run to the side of the house.
    Thanks!
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,054
    We are going with the Goldline GL-235 however the installer is putting the system in for us. If you are going to DIY, look at ebay, can be bought for $285 includes free shipping. Hope this helps Post pics when you do the install......
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by Brentr
    Same for you Brent; post pics of the install and let us know how it works out for you! When are they getting started?
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
