Thread: tiny bubbles
    tiny bubbles
    Hello- I know nothing about pools. We purchased a home with a four year old pebble tec pool that has a Hayward vacuum and sand filter. It is a regular chlorine pool. We have never experienced any problems until we purchased a new robot guy that travels around the pool. The new vacuum part worked great until we attached the new hose that came with the vacuum. The Hayward rep came to the house and he seems stumped. Apparently, they put some sort of UV coating on the newer hoses that is attracting tiny bubbles to it which, after time, makes the vacuum float above the bottom of the pool. We have always noticed that the pool is akin to champagne in that it seems almost aerated with little bubbles when agitated. Our chemicals always test normal, although, we are due to have the pool drained due to the hardness level. Does anyone have any other suggestions or has anyone else experienced this problem. Thanks.
    Houston-area (Katy, TX)
    10,000 inground plaster pool
    1.5 HP, 2-speed Hayward
    Cartridge Filter
    400k BTU gas heater
    E-Command 4 automation
    Re: tiny bubbles
    OK, I was bad and didn't read that you needed other information. The pool is 20,000 gallons. It has a spa, water features and really strange fire pots although I don't think any of that is contributing to the tiny bubbles since we only turn that stuff on a couple of times a year.
    Cartridge Filter
    400k BTU gas heater
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: tiny bubbles
    Welcome to TFP!
    I have to wonder about a water chemistry issue. Can you post a full set of test results?
    South Central NJ
    3,192
    Re: tiny bubbles
    Quote Originally Posted by Jen
    What model equipment? For example, 24" sand filter, 1-1/2 HP Super Pump, Navigator, etc....
    How long have you been in the home now?
    I assume that means you were using the old hose for a period of time. What happened to the old hose and how long were you using it?
    Air sticks to things under water sometimes, depending on the surface it's adhering to. Eventually, it falls off due to agitation. WRT to the hose, many hoses for suction side cleaners float and need doughnut shaped weights to stay at the correct angle the cleaner needs.
    A picture or a link to an album at photobucket.com of the pool with the sweep and equipment will tell us a lot!
    Scott
    Owner of - PoolGuyNJ LLC
    30,414
    Re: tiny bubbles
    Hi, Jen,
    Welcome to the forum!
    I second JohnT's idea of a full set of water chemistry test results. Do you have them available? S-o-o-o many issues can be solved getting your water in balance.
    Toms River, NJ
    151
    Re: tiny bubbles
    It sounds like a chemistry issue, perhaps a very low calcium hardness, but without test results we can't know for sure. If you don't have a test kit yet, can you get test results from a pool store?
    45,180 gallon 26' x 53' IG Vinyl, irregular shape. Hayward sand filter / pump. Polaris AutoClear SWG, supplemented with a Hayward Automatic Chlorinator (In-Line). Hayward 400K BTU heater. Paramount "turnover" system. Polaris 480 PRO cleaner.
