Results 1 to 10 of 10
Thread: What filter do I have?
    I bought a used sand filter. The only numbers on it are on the valve label 27-2599 6/98. It is about 24-27 inches high (not sure how to measure it) and 6 feet in circumference I need to get parts and get it running. Please tell me what it is?
    Barbara
    ~29K gal, 20'x36' rectangular, outdoor IG plaster, built in '74. Intelliflo VF; Sta-rite system 3 w/300sq ft. Liquidator 8Gal-3/8ug; Polaris 380 sweep & PB4 booster. Equip. is in shed on ground level pad.
    Mar 2007
    Ontario
    211
    Re: What filter do I have?
    A pictures worth a 1000 words. If your able to post one.
    16x32 inground vinyl 8' deep end
    1hp Northstar Pump, 20" Sand Filter
    6ft Double Lounge, 2 Aqua Lamps w/remote
    216sqft Sungrabber Panels (9- 2'x12') a little undersized
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    For posting a pic, the easiest way is to use a photo hosting site like Photobucket.com. The accounts are usually free. When you upload, select the "large" size. then you just copy and paste the "IMG" code into your message here, and the pic will appear.
    Posting a pic should yield better results.
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Quote Originally Posted by dacmedispa
    Barbara
    Could it be....
    http://www.poolcenter.com/parts_filter_ ... agelus.htm ?
    See also...
    tagelus-pac-fab-ta-60-handle-positions-t10397.html
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    We are not sure we even have this hooked up correctly. Our pool is 10 x 24 and at the deepest is 5 foot
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    The pump is Pentair, so the filter is probably a Tagalus or Sand Dollar.
    Are you having filter problems? If so, we can probably help, even if we don't know the exact model of the filter.
    BTW, do you have trouble priming the pump? - you've got a lot of extra pipe going into the pump.
    Luv& Luk
    -Ted
    22,553
    That looks exactly like my Pentair Sand Dollar. Even the base where the pump used to sit. Since it's 24" diameter, it's most likely a SD-60. You should be able to get parts from that number.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    That is a monster Hartford loop!
    Not the filter, its a plumbing term. Sorry for the possible confusion.
    Factory Warranty Station for:
