Thread: Prognostic Balancing Question
    svenpup's Avatar
    Nov 2009
    Sacramento, CA
    835
    Let's say my pH is 8.0 and my TA is 75 (roughly where I want it).
    The Pool Calculator says to get my pH down to 7.5 would take 23 oz of muriatic acid.
    If I put 23 oz muriatic acid into the "Effects of adding chemicals" section it says that it would lower my TA by 4.
    Does this mean I should also add 20 oz of baking soda to offset the soon to be realized drop in TA?
    TFP Method Advanced Intermediate
    • 17,500 gallons - In Ground - Plaster - Hayward Swimclear 3020 Cartridge Filter - Sta-Rite Max-E-Glas Main Pump upgraded with A.O. Smith B2980 E-Plus New Centurion Two-Speed Motor - Polaris 280 Cleaner with Polaris PB4-60 Booster Pump - TightWatt2 Timer - Taylor K-2006 Test Kit - Pool Pilot Digital Nano SWCG
    Helpful Links: Pool School, BBB for Beginners, How to Shock (hint...it's a process not a product), Chlorine/CYA Chart, Jason's Pool Calculator
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    Re: Prognostic Balancing Question
    In practice, even with the additions of muriatic acid, TA tends to be fairly resilient. Perhaps my observation fits within what you would expect with testing error, but my TA has been between 75 and 95 ppm for months and months and has "resisted" change in spite of countless pints of muriatic acid. More frequent pH adjustments using small amounts of MA are recommended - especially so in winter when the CSI plummets due to low water temperatures. Depending on your other values (CH, Salt, CYA) you probably don't need to lower your pH from 8 to 7.5 ... a higher pH should be OK.
    JasonLion or chem geek can respond regarding how the calculator is intended to work.
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    30,426
    pH at 8 is too high. I suggest you bring it down to 7.5 sooner rather than later.
    You will not be able to test for the 4ppm TA drop since most TA tests are only accurate to plus or minus 10ppm.
    You could certainly add the baking soda if you like but you will likely never be able to tell (test) that it worked. I'd leave it.
    There will always be things raising and lowering the TA. Almost any time the PH changes the TA will also change. So, you shouldn't worry about TA changes of 4 ppm. It is impractical to aim for an exact TA level anyway. It is going to vary somewhat. As long as the TA is +-10 of your desired level, then it is just fine and you don't need to bother adjusting it.
    There is actually an important principal behind this. Don't try to micromanage your levels. You should allow things to vary within reasonable ranges so you aren't constantly adding chemicals. That is why the recommended levels are specified as ranges.
