Results 1 to 20 of 20
Thread: Downspout Water....Pool?
    We just moved into this house last summer and this has always been a mystery to me. One of the downspouts coming off the roof is diverted away from the patio/pool area via a 4" corrugated pipe placed on the ground.
    It runs about 2o feet parallel to the house and then goes out into the yard a couple feet, which places it clear away from the pool. It is clear that the intent was to keep roof water away from the pool, but why?
    There is a drain between the previously existing patio and the newly installed pool. Wouldn't this be able to drain the possibly tainted water? We hate looking at the huge black corrugated pipe that snakes along the side of the house.
    I can post pics later if it will help but i wonder if anyone had expertise or experience with this?
    10,000 gallon
    Viking Freeform Fiberglass Inground Pool. FNS Plus DE Filter Pentair Challenger .75hp pump
    NC KANSAS44
    Dec 2009
    Central Massachusetts
    2,690
    Re: Downspout Water....Pool?
    If the pipe wasnt there, where would the water from the gutter go? Picts would help. Normally those pipes are buried and carry the water away from the house.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    Look at the base of the house, you can see the corrugated pipe.
    10,000 gallon
    NC KANSAS44
    mas985's Avatar
    Pleasanton, CA
    11,737
    If it is a leaky drain pipe with weeping holes, then perhaps they didn't want water to get under the pool. You could drill a hole in the concrete to go under the patio and then bury the pipe.
    [EDIT] Never mind, I think I understand now. The owners probably didn't want water running on the patio. It can cause mold and algae.
    Mark
    South Central NJ
    3,192
    I would have a gutter guy replace the section with the down spout to one without a downspout and then repitch the gutter to the other
    side of the house.
    Scott
    Owner of - PoolGuyNJ LLC
    Quote Originally Posted by PoolGuyNJ
    side of the house.
    Scott
    That isn't possible. You can't see the rest of the deck, but that section ends at the fireplace chimney and drains a large section of gutter.
    10,000 gallon
    NC KANSAS44
    South Central NJ
    3,192
    Why can't the gutter be repitched the other way?
    Scott
    Dec 2009
    2,690
    Thats the best fix, i would think. Just move the downspout on the other side. Take some more picts on the other side of the house so we can see the issue.
    I see why they put in the pipe so the water wouldnt run in the pool. I have all my down spouts run underground so the water runs away from the house.
    Quote Originally Posted by bk406
    That would seem to be the fix but again, it isn't. I can't take more pics cuz it is dark. But there is a roof over that deck you see to the left and gutter all the way around it. The otherside already has a downspout. The only option would be to plug this downspout and that would not be sufficient drainage for the roof.
    Regardless, what is the issue with roof water? Is it the shingle sand? Or what am i missing?
    10,000 gallon
    NC KANSAS44
    Ft Lauderdale, Florida
    1,455
    Rainwater, especially draining off the roof would just add extra contaminants for you to have to treat chemically. Rather than allowing the water to drain onto the deck, and possibly seep under the house, it was probably safer for them to make sure it drained away from the house. I don't think the main intent was to prevent the water from flowing into the pool, but rather, to prevent the water collecting on the deck and causing damage to your house's foundation.
    That's just an opinion.
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    30,403
    Well, I'm comfortable that this would be a code violation but......
    you could insert a 4" PVC pipe through the "chimney" (I'm assuming it's a hollow box that has a stainless triple-wall pipe inside of it) and then create some kind of clever connection at each end of the pvc pipe to tie the two gutters together.
    That's probably too much gutter length for one downspout (so it will overflow when you get one of those Central Kansas thunderstorms) but it will handle the flow 95% of the time and you will get rid of both the downspout and the black pipe.
    Aug 2009
    North Central Texas
    1,358
    It looks to me like the commonly used piping to keep water from depositing too heavily in a concentrated area; in your case off of the patio, from running across the patio into pool, and to divert water away from house foundation. It looks like a temporary measure and/or afterthought measure. They are commonly used to divert water away, buried for most permanent installations. Many are perforated to let water gradually release into an area. A lot of times, when done properly, when they are buried, they are wrapped with a type of landscape material to keep mud/silt from entering and clogging the pipe. I have several, buried, that run a few inches below grade, running around two sides of the house, in pretty narrow planting areas, lining the house foundation, that carries water from a drain by the garage door/concrete slab to another drain that goes down the hill but does a bit of releasing water along the way to water plants in the narrow soil area on west side of house, between the foundation and pool decking.
    I have another unburied, leading away from a downspout, on new gutters I put up a few years ago. The old gutter downspouts emptied under the deck and did quite a bit of erosion of the soil around the concrete footings for steel peirs for deck. This installation is "temporary" (sic) as I have but not placed/connected a bunch of 50 gal barrels, for water collection off of that roof, from the downspout.
    I have another long piece, waiting patiently, to be put to use when needed.
    I'm sure this pipe is called several things. It is pretty inexpensive and very easy to work with, and does its job well.
    I wrote this hours ago but didn't post and I see that there are other post, that I haven't had time to read. You could place a decorative water collection barrel below the downspout and run the overflow more hidden.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Brentr's Avatar
    Oct 2009
    Jacksonville, FL
    2,053
    Why not continue the gutter from one side around the chimney and connect to the other end of the gutter? It may not look too pleasing but you can then eliminate the downspout and all will be well.
    6,000 gal, IG free form,Beach Series Antigua by Marbletite Pebble finish,Sheer Descent, IG Fountain, Dolphin / Mermaid Statues,Dura- Glas 1.5hp pump,Hayward Pro-grid DE4820, Aqua Rite SWG with T-Cell 15,Heat Siphon Heat Pump DX 5.0 109,000 btu, Pool Cage, 1800sq ft Tremron Estate Pavers,Aquatherm Ecosun Solar Panels 192 sq ft with GL-235 Controller,Pentair IntelliBrite, Apollo Magnetic Stirrer Our New Poolbuild, Jacksonville, FL yr 2009 Solar install Outdoor kitchen upgrade
    Jul 2009
    Shawnee, Kansas
    92
    I cannot see the picture for some reason, but my guess, to answer your question, is that they do not let the roof water go into the pool becuase during a Kansas spring rainstorm (Shawnee, KS here) you already have enough extra water going into your pool, that you will have to waste anyway, why add more to the mix. A good downpour can easily add an inch (I wish it was this little sometimes) of water just across the surface of your pool, add to that the same amount falling on a roof (which could easily be many times the size of your pool) and being diverted directly into your pool would mean just that much more water to waste out. ADD to that the effct on your chemicals, you are just throwing money, time and energy out the window to correct something a little piece of black pipe can fix. MY own $.02. By the way, I have the same black pipe diverting a downspout around my equipment pad that I have just never burried.
    Matt
    20,000 gallon, sand filter, IG vinyl
    Vero Beach, FL
    462
    I don't see where the drain is located, but you can give it a try. Remove the black pipe and during the next rain see where the water flows and if the drain is capable of handling it. That would be a very good solution assuming you always keep the drain free of debris.
    Otherewise, here is what I would do....
    Use rectangular gutter downspout and elbows on edge and on top of the slab, hugging the siding all around the outside of the fireplace to bring it out to the dirt. Then burry the black pipe as much as possible. You can paint the gutter to match the siding and it will look better than the black pipe.
    The idea about using pvc to go through the chimney is a good idea provided you can make sure you have watertight seals. You'd hate to have leaves and such block the end and have water pouring into the chimeny area.
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Ohm_Boy's Avatar
    Orlando, FL
    1,344
    While rainwater, in itself, may not be chemically horrible (but it can be pretty bad in some areas), roof runoff typically carries shingle aggregate, bird droppings, leaves, rust, and other contaminates with it, and you don't want that in your pool.
    In your case, you seem to be limited to breaking concrete and digging to submerge the drain tube, but I think you should call a couple of gutter guys out and have them look and tell you what their suggestions would be. Since they are in the business, they have seen a lot of ...interesting... installations, and will have insights that we lack. They should offer a solution and estimate for free. See if they can come up with anything.
    Dec 2009
    2,690
    Quote Originally Posted by lborne
    Thats what I would do. Just pitch it a little around the base of the chimney.
    I cant see the drain between the patio and the deck either, but my guess is that it is not sufficient to stop all the water from going in the pool. Several hundred gallons will come off that roof with just an inch of rain and flow right into the pool.
    (EDIT: Post above was added while i was typing). The idea to have a gutter company come out and look at it is a good one too. They should give you a free look-see.
    You can see what the downspout is draining here. This is why i can't plug it. It drains a LOT of roof. The only other one in this field is on the left side of the pic.
    10,000 gallon
    NC KANSAS44
    South Central NJ
    3,192
    Why not run a leader under the deck and under the fence?
    Scott
  20. Back To Top    #20
    Scott
    That is an option I suppose, but again probably not ideal. That would give two downspouts dumping in the same area. An area which is bordered by a fence within 5 feet. I like the idea of trying to use aluminum extensions and running under the fireplace and seeing if i can at least get it to dump somewhere that isn't parallel to the pool .
    It seems like to me if i get the water to at least dump in the grass than the issue of direct run off from the roof gets somewhat muted. I can see water having enough force to go down the patio and climb the slope of the pool deck to enter the pool.
    I can't really see it having the force to traverse the lawn, edging, rocks and then climb the pool decking.
    10,000 gallon
    NC KANSAS44
