Thread: Thinking of switching to a SWG
    I do not want to hijack a thread but I am thinking of switching to a SWG but do not know a thing about them!
    If the possibility that you might be hijacking a thread occurs to you, then you should start a new thread Thanks JasonLion
    14 x 30 IG pool with 1.5 HP pump - 4.5 feet deep
    use smart sticks for clorine
    New 20 or 22 inch sand filter system
    How much would it cost to convert?
    Is it a hard process?
    Does it still use most of my existing pump, filter system and so on?
    I am just in the process over the next 30-60 days of changing the liner and replacing the light as it is burnt out and thought it might be a good idea to do this at the same time.
    If someone can point me to some sites that sell them and where I can read about them.
    14 x 30 above ground vinyl indoor
    New Pentair Whisperflow 1.25 HP pump - pump runs 18 hours/day
    New 22 Hayward Sand Filter with Zeobryte
    New Vanee HRV system
    Re: Thinking of switching to a SWG
    Adding a SWG is fairly easy, and experienced installed can usual install one in under an hour. The SWG cell is inserted in some existing pipe and the power supply/control panel is mounted somewhere. None of your other equipment is affected.
    Here is one place to read about a SWG. There is also a good overview in Pool School.
    How handy would I have to be to install one of these myself? ... or is it better left to a pro?
    20,500 gal gunite pool w/ PebbleTec and infloor cleaning system.
    Sta-Rite System 3 cartridge filter.
    Houston, TX
    South Central NJ
    Reasonable handy and knowledgeable. Use the right glue, measure twice, cut once. Have a good understanding of outdoor wiring requirements and tools.
    Owner of - PoolGuyNJ LLC
