Thread: Carbonated pool water
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,074
    I pumped out several inches of water before dawn this morning when the rain was starting. Then I went off to work, telling my wife at what level to pull the plug before she left for her errands. When I got home, it was very high again. The rain must have added 6" today.
    From reading here, I expect to see the pH very acidic - I haven't tested it yet, since it hasn't had time to circulate. So I turned on the filter and brushed some debris around by the light of the pool. Where the hot tub spills into the pool, it's very easy to see the bubbles - I have a carbonation cloud about 3' diameter and 4' deep. It's really neat looking. Too bad the picture can't capture the effervescence!
    Jan 2009
    Cupertino, CA
    1,966
    Re: Carbonated pool water
    People have different experiences. Lots of people find that the drops bouncing when they hit the water will aerate enough to counteract the incremental acidity and see the pH go up. Normally with a cover I see the opposite (pH drops a little because the rain is actually acidic), but yesterday's rain came with serious wind that rolled the cover up the long way, and my pH just read 8.2.
    --paulr
    BBB "Intermediate Swimmer"
    Feb 2008
    Denton, TX
    5,061
    Really interesting thread here! I wish that I could see what Richard is describing in person as that would be something to see.
    I have never noticed much of a pH change with rain here; even lots of rain. Perhaps this has to do with where you live. Usually, I will notice little more than some water cloudiness and, quite often, a big drop in FC. In the spring, rain will often add a large amount of dust (from west Texas inflow) and it takes a while to filter it down sometimes. We will also get tons of pollen in it .
    Aug 2009
    North Central Texas
    1,358
    Quote Originally Posted by 257WbyMag
    Being somewhat of a neighbor (probably 40-50 miles south) I usually see pretty minimal changes in pH from rain, also. Dust is constant, of course, and I can attest to the difficulty in filtering it out. I'm pretty sure that is the reason most of the people around here (all that I know of in fact) use DE filters that can't always get it all filtered out.
    gg=alice
    1981, 25K, IG, Blue Plaster 1996, somewhat oval, widens a bit at shallow end, 1.5" pipes, 2" at Pad, 1 separate main drain, 1 skimmer, 4 returns + dedicated cleaner return, 10 ft deep end with very fast decline from shallow, Pentair Quad 80 DE, Pentair Intelliflo VF, 3/4 HP Booster Pump (equipment pad about 8 ft below top of pool), Challanger 3/4 Trash/Emergency Pump 120v, Polaris 280 (pressure), iRobot Verro cleaner (robotic), Aquabot Turbo (robotic), Jacuzzi Tracker 4X (vacuum) Pool Blaster (Buster), Two (2) PoolSkims, Solar Breeze (solar powered top skimmer) (beta to ver. 2, release date 2010), ColorSplash LED replacement bulb. Aries 550 gal separate spa, 2002 (our 3rd and BEST spa) , BBB-Bromine
    Richard320's Avatar
    Jan 2010
    19,074
    It's not as impressive today as it was last night. But you can see that the water over the spillway isn't moving all that fast, and it's not foaming, yet the bubbles start quite a ways down and rise to the surface.
    [youtube:164vlysl]rwGhl6Umpao[/youtube:164vlysl]
    Hmmm.... doesn't display in preview mode, let's hope it works for real or else you'll have to copy-n-paste.
    Fixed. JasonLion
