Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Trying new avatar
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Trying new avatar
    Looks small to me.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Trying new avatar
    I deleted my old avatar but when I get this new one to the specs required this is what it looks like. What's up???
    Lynn
    polyvue's Avatar
    Aug 2009
    Sacramento, California USA
    1,215
    It appears that your avatar is only 20x20 pixels.
    Mine is 98x95 which I affixed using Micosoft Office Picture Manager.
    Other programs should enable you to crop/shrink a favorite image so that the image file is less than or equal to 120x120 at less than 9 kbytes. Check the image's size and pixels via folder/directory listing before uploading it. You can even grab mine (right click, copy) and paste it into a folder before uploading.
    Note that I charge a monthly fee for continued use: $7.70
    14,555 gal in-ground 16'x29' white plaster Pool w/spa (2007); Goldline Aqua Logic AQL-PS-8 control w/Aqua Cell 15 Salt Water Chlorination (SWCG); Hayward TriStar 1HP (1.85 SF) main / 1.5HP (1.60 SF) spa pumps; Hayward Swimclear cart filter C4025, ColorLogic LED lights; Tankless SP-18-4 electric heater; Polaris 280 cleaner.
    __
    View of spiral galaxy in Ursa Major NGC6217 - Hubble Telescope 2009
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    But that's how small I had to make it to be under the 9kb size.???? Help
    Lynn
    polyvue's Avatar
    Aug 2009
    1,215
    Some applications allow you to reduce the byte size without cropping it.... by reducing the resolution (or clarity) of the picture. What program are you using?
    __
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I'm just using the Windows Photo Gallery on a new lappie I recently got.
    Lynn
    polyvue's Avatar
    Aug 2009
    1,215
    Try using Microsoft's Paint program. It should be under Start/Accessories on your Windows computer. Bring up the (over-sized) image, on the Image menu, note the number of pixels w/ Attributes... and then reduce the size of the picture with the Stretch/Skew function (Ctrl-W, if I remember correctly) by sizing it 80% or whatever works to reduce the picture to the size you want.
    Save it under a different name. If you make a mistake or don't like the output, re-open the unmodified larger version and try again. If you don't want to mess with yours... practice with the file I uploaded. It's proportioned to be a square.
    __
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks polyvue. I will see what I can do.
    Lynn
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Finally got one to work. I can't get the file size small enough on this one, which is the one I wanted. If I get file size small enough you can't see the pic.
    Lynn
    polyvue's Avatar
    Aug 2009
    1,215
    Check your PMs.
    __
    Try this version:[attachment=0:2qybg5zh]Av-UT-Titans1.jpg[/attachment:2qybg5zh]
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks guys, for helping a computer challenged member
    Lynn
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    The biggest problem I can see with it is that ugly orange and columbia blue... :P
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    polyvue's Avatar
    Aug 2009
    1,215
    Quote Originally Posted by MikeInTN
    Oh sure... but look who's talking!
    woof! woof!
    __
    no-mas's Avatar
    Jun 2008
    FL
    405
    Ummm... I'm trying to be a good boy and not comment.
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Mike, I figured I'd hear from no-mas about this, but YOU I'm stunned.
    Go ahead Gator, I was waiting on you (and I'm being ladylike with the spelling of Gator . and I know, you know, huh, no-mas )
    Lynn
    no-mas's Avatar
    Jun 2008
    FL
    405
    Quote Originally Posted by orthofish
    ....(and I'm being ladylike with the spelling of Gator . and I know, you know, huh, no-mas )
    Yeah, yeah, I know the one
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Quote Originally Posted by polyvue
    woof! woof!
    Now, don't make me sic the Schnauz on ya...She'll plumb near lick ya to death if I do!!
    Intex 8110 SWCG
    "Fear the Schnauz!"
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I know, I know, you don't expect such things out of fellow Tennesseans, but I absolutely can't stand the Vols or the Titans. Being around a bunch of obnoxious Vol fans when I was younger turned me off of them; plus, I'm a fan of the Fighting Irish, so most UT fans despise me as well.. (We've also got season tickets to Vandy). Pro ball, I've always been a Steelers fan, and the Titans are still the Oilers to me, and will be as long as Bud Adams owns them.
    Now I do pull for the Predators, so that's a good thing, right??
    Intex 8110 SWCG
    "Fear the Schnauz!"
  20. Back To Top    #20
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Well, you might live close to me, but I don't see us watching any ballgames together I can't stand any of your afore mentioned teams. Except for the Preds of course.
    Lynn
