Results 1 to 11 of 11
Thread: Solar Cover
    Solar Cover
    Can anyone tell me how effective is a solar cover for a pool that has arches on the sides if the cover only covers most of the pool (i.e., not the arches at the edges) so the pool is not 100% covered.
    Thanks for sharing, Udi
    13x28, 8500 gal, basic plaster, Hayward cartridge fltr w/1 hp pump
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Re: Solar Cover
    Quote Originally Posted by bll
    It will likely lose some of it's effectiveness as there will be some places where the water can evaporate or lose heat at night...I get the picture of what you are saying about the outline of your pool but how wide are the arches. One thing you could do is get a cover that is wider than the outline of your pool and trim it to fit the arches...Or you can just get some remnants and cut pieces to fit your arches. YOu can easily attach your arched pieces to your main cover with cable ties or what most people call zip ties...I hole punch mine and then run the zip ties through the holes and tighten them down leaving about an inch diameter to play with...If you tie it down too tight, you run the risk of tearing your cover. Let me know if this works for you...
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Jan 2009
    Cupertino, CA
    1,966
    Re: Solar Cover
    My pool is irregular (vaguely triangluar). I bought a cover that was longer than the long side, but not wide enough, then used a scrap to cover the leftover bit. It's not 100%, but I figure if you cover 90% of the pool you get 90% of the benefit. (Evaporation should be relative to the exposed surface area, and that's the major contributor to cooling.)
    I don't know if this diagram would help....
    Code:
    One long strip with some cut off at the narrow end, and that becomes the bit used to cover the little leftover part.
    Covers usually come as rectangular but sometimes oval, you can play around with a sketch on graph paper to see what would work best.
    --paulr
    BBB "Intermediate Swimmer"
    Re: Solar Cover
    Thanks Cobby and Paul.
    The arches are about 1 feet tall (in the highest spot) and 6 feet long. I have 3 of them from each side of the pool. The pool is 20x40 without the arches. I am just concerned that if I cut a cover to include the arches it will be a hustle to fold / use a reel...
    Jan 2009
    Cupertino, CA
    1,966
    Re: Solar Cover
    Sounds like the surface area in the arches is relatively small, I just wouldn't bother trying to cover them if it would make it a pain to get the cover on and off.
    And the thing is, covers don't last forever; when the first one gives out, you'll know what you want to replace it with. What I have right now works okay, but next time I'm going to get 12' wide instead of 16' so the bigger section won't be so annoying to handle.
    --paulr
    Feb 2008
    Northwest Indiana
    902
    Re: Solar Cover
    Bill...If you went with something like 22 ft. wide you could easily over lap and cut the shape of the pool into the cover...they are easily cut with scisors. Then you could just fold the arches over as you wound it onto the reel...or you could use my method for cutting and attaching. I will try to find a picture and post here to show you what I did. I don't know if I have them any more. But it was simple to do...this way you could just pic the arches up and fold them over and they are always attached to the main cover section.
    Beave
    Re: Solar Cover
    I have a 38ft * 15ft rectangular pool and the largest solar cover I could get was 35ft long so I had for a while a gap at the end of the pool. It still saved a heap of water evaporation and heated the pool by 9F. I found the biggest things with the solar cover was the ease of getting it on and off. In my first season with the pool cover I was too particular about keeping it on correctly and so less time was spent in the pool cos' it was a hassle, so it has to be easy and quick. The cover can be a bit heavy to roll up and get kinks in it so if you have odd shaped bits, I would only use them in the off season to protect your pool. If it takes the kids only 30 secs to roll it up and dive in, they will use it. Hope this helps.
    20,000 gallon 38ft * 15ft Concrete with Vinyl Liner Poolrite S6000 sand filter, Poolritepump
    Feb 2008
    Northwest Indiana
    902
    Re: Solar Cover
    Quote Originally Posted by bruiser71
    that is why I cut mine in sections...I have four pieces...two full center pieces and two semi circle pieces that are the outside pieces...I can get in the pool and quickly roll them up and put on the side rails and be ready to swim in about 10 minutes...I roll carefully to keep any **** on the cover from getting in the pool. It takes actually less time to put them back in place...We swam here until Mid September last year, using the solar heater and the solar covers.
    Beave
    Feb 2008
    Northwest Indiana
    902
    Re: Solar Cover
    Try Doheny's Water Warehouse. www.Doheny.com...They have covers for sale as large as 30X60 rectangular I am sure you could find something that will work for you....
    Beave
    Toms River, NJ
    151
    Re: Solar Cover
    That site is way expensive.
    45,180 gallon 26' x 53' IG Vinyl, irregular shape. Hayward sand filter / pump. Polaris AutoClear SWG, supplemented with a Hayward Automatic Chlorinator (In-Line). Hayward 400K BTU heater. Paramount "turnover" system. Polaris 480 PRO cleaner.
    Feb 2008
    Northwest Indiana
    902
    Re: Solar Cover
    Quote Originally Posted by baudilus
    yeah...they are for the most part a commercial pool site...but if you look around or get the catalog...they do have some reasonable deals...ANd there aren't a whole lot of places where you can find a solar cover that big is there?
    Beave
